6speed Technical Information forum This area is intended for members to post their technical questions that will be answered by anonymous experts posting as 411. Members may provide knowledge but sponsors are asked to not post in this forum.
Exhaust studs replace or not?
Old Apr 4, 2014 | 02:03 PM
411's Avatar
411
Technical Advisors
411 Is a GOD !411 Is a GOD !411 Is a GOD !411 Is a GOD !411 Is a GOD !411 Is a GOD !411 Is a GOD !411 Is a GOD !411 Is a GOD !411 Is a GOD !411 Is a GOD !
I may have given the wrong advice. I was under the understanding you were removing the Exhaust manifold from the engine, not the Turbine outlet pipe. Your request stated Exhaust. From past experience it is the studs in the Cyl heads that always break and give grief. Best to check the Torque and stud size. Suggestion would be to swap the studs for Stainless types and never have the problem again. Removing the Turbo and removing the studs should not that big a deal.
Old Apr 5, 2014 | 01:16 AM
xbox_fan's Avatar
xbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond repute
Yes makes sense now
Old Jul 2, 2014 | 12:44 PM
Alan C.'s Avatar
Alan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond repute
Bottom line is steel and aluminum are most prone to corrosion
Back form the dead. Aluminum in contact with iron, main element in steel, will be sacrificial to the iron. Aluminum by itself will form an aluminum oxide on the surface. That oxide is pretty stable.
Old Jul 23, 2014 | 04:51 PM
RebuiltM96.21's Avatar
RebuiltM96.21 is a name known to allRebuiltM96.21 is a name known to allRebuiltM96.21 is a name known to allRebuiltM96.21 is a name known to allRebuiltM96.21 is a name known to allRebuiltM96.21 is a name known to all
I fitted stainless steel studs+nuts . Got a $36 kit on Fleabay. You need to be able to measure stud threads accurately to make sure you get the correct kit.Similar to this:
http://www.ebay.com/itm/10-Piece-M8-...aeb1c2&vxp=mtr
Jun 10, 2017 07:45 PM
vr6tee
Aug 29, 2015 03:52 AM
Lucid Moment
Aug 20, 2015 02:22 PM
