6speed Technical Information forum This area is intended for members to post their technical questions that will be answered by anonymous experts posting as 411. Members may provide knowledge but sponsors are asked to not post in this forum.
Need help identifying drain and fill plugs on 997 front differential
Old Apr 5, 2014 | 07:40 PM
mccarthy_sean's Avatar
mccarthy_sean is infamous around these parts
I posted this on Rennlist and haven't gotten anywhere. I figured I'd see if anyone here on 6speed might know the answer.
I'm getting ready to change the gearbox fluid in my '06 C4S and the owner's manual calls for changing the fluid in my front differential at the same time. There is quite a bit of DIY info out there on changing the gearbox fluid, but extremely little on the front diffy.
For some reason the dealership wants $325.00 to do the fluid change in the front diffy which is almost $70 more than the gearbox (both jobs book at 1.5 hours and call for the same type of fluid). I asked the service manager why the difference and he said it was because of the different fluid amounts between the two. Not sure where these guys learned math . . . the gearbox contains around 3 times as much fluid as the front differential. Something doesn't add up so I am going to tackle the job myself.
Below are photos of a 997 front differential which was removed from a car. If you look at the bottom, you will see two plugs that resemble DRAIN plugs. However only one can be the correct one (I'm guessing #1, but figured I'd ask the forums first). Can anyone confirm? If I am correct and #1 is the drain plug, anyone know what the #2 plug is for? Is #2 a drain plug as well?
Also, based on the drawings in the PET, I am guessing the FILL plug is the one the arrow is pointing to in the second picture. Can anyone confirm that as well? Anyone have any gotchas to share on changing the front diffy fluid? There really isn't much on this subject out there, so any information we can post should be able to help others. Much appreciated.
Sean
ID:	356070   Click image for larger version
Old Apr 6, 2014 | 09:18 AM
cjv's Avatar
cjv
Moderator
Sean,
Try posting your question here. https://www.6speedonline.com/forums/...ion-forum-184/
Old Apr 14, 2014 | 06:13 PM
stronbl's Avatar
stronbl has a spectacular aura aboutstronbl has a spectacular aura about
Hope these are of some use ... tightening torques are 21 ft-lbs for each.
Name:	Front drive oil fill location.png
ID:	359835   Click image for larger version
Name:	Front drive oil drain location.png
Old Apr 14, 2014 | 10:35 PM
Thanks for the drawings. I'm pretty sure "A" is the fill plug, but is "B" really the drain plug? Drain plugs are usually at the bottom of the sump, and if I opened up "B," it looks like I wouldn't be able to get all the fluid out as the plug in the photo appears to be on the side of the case.
Also, are these drawings for a 997.1 C4 and C4S front differential? The reason I ask is I hear the 997.1 Turbos have 2 drain plugs while the C4 and C4s only have one.
Sean
Old May 2, 2014 | 03:08 PM
stronbl's Avatar
Sorry for the late reply. These are for 997.2 C4/C4S. PM me and I can send you some extra pages with the text if you wish.
A is fill & check plug and B is drain plug.
COBB Tuning
Jan 1, 2025 09:02 AM
Enemy
Nov 10, 2015 08:01 AM
gulf gt
Aug 27, 2015 10:27 AM
TrackOne
Aug 20, 2015 12:56 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
