6speed Technical Information forum This area is intended for members to post their technical questions that will be answered by anonymous experts posting as 411. Members may provide knowledge but sponsors are asked to not post in this forum.
DME Scan produced some codes I need help with
Old Apr 8, 2014 | 09:35 AM
Mspross's Avatar
Mspross is infamous around these parts
I hope this is the correct place to post this question, let me know if it isn't.
Recently picked up a 2006 C2S, with the Carrera Power Kit (X51), and it has about 22,000 miles.
Car has been running fantastic, until the other day threw the check engine light. I ran a scan, using the Durametric, and below are the results that I'm most concerned about (There were a few others, which I'll try to address later).
I've done quite a bit of research, but basically I'm back to square one. I do have the service manuals, but am having trouble locating what exactly the issue is. Car is still running fine (to me), but would like to get these addressed before a bigger problem occurs. Any help or assistance would be greatly appreciated.
Note, I believe P0420 and P0430 are being thrown due to the Fabspeed aftermarket exhaust that is installed. I'm thinking that I can install some spacers for the O2 sensors to help alleviate this issue. Please advise if I'm correct.
The log of the codes is as follows: (P0660, P1043, P0420, P0430).
Bosch Digital Motor Electronics Motronic 7.8.1
Module Identification
Part Number 997.618.624.06
Supplier Part Number 00419100A822
Current Fault Codes
P0660
Intake pipe switchover final stage
Freeze Frame Information
Fault symptom open circuit
Self test not complete
Fault status fault not present
Warning light off
Fault path num 50176
FLC/HLC state 10
Fault check state 0A
FCM line status 00
FCM output data (mil, svs) 44
Error Path Status 1537
Counter Continuous Error 0
Counter Accumulated Error 65280
MIL on counter 255
MIL off counter 12
Clear counter 40
Frequency counter 1
Calculated LOAD value 91 %
Engine coolant temperature 72 °C
Short Term Fuel Trim - Bank 1 0 %
Long Term Fuel Trim - Bank 1 0 %
Short Term Fuel Trim - Bank 2 0 %
Long Term Fuel Trim - Bank 2 0 %
Vehicle speed sensor 0 km/h
Ignition Timing Advance for #1 Cylinder 0 °
Intake Air Temperature 37 °C
Absolute Throttle Position 13 %
Commanded Secondary Air Status 04
Commanded Evaporative Purge 0 %
Barometric Pressure 1000 kPa
Relative Throttle Position 1 %
Ambient air temperature 3 °C
Absolute Throttle Position B 12 %
Commanded Throttle Actuator Control 2 %
Long term secondary oxygen sensor fuel trim - Bank 1 0 %
Long term secondary oxygen sensor fuel trim - Bank 2 0 %
Fuel system 1 status 067F
Engine RPM 128 rpm
Air Flow Rate from Mass Air Flow Sensor 2 g/s
Absolute Load Value 46 %
Total operating time (first occurrence) 760.3 h
Total mileage (first occurrence) 36186 km
P1043
Exhaust flap control final stage
Warning light off
Fault path num 50432
FLC/HLC state 10
FCM line status 00
MIL on counter 255
MIL off counter 12
Clear counter 40
Frequency counter 1
Engine RPM 128 rpm
P0430
Bank 2 catalytic converter system insufficient effect
Fault symptom below limit
Warning light off
Fault path num 29696
FLC/HLC state 10
Fault check state 0B
FCM line status 10
FCM output data (mil, svs) 22
Error Path Status 769
Counter Accumulated Error 512
MIL on counter 2
MIL off counter 3
Clear counter 40
Frequency counter 5
Calculated LOAD value 28 %
Engine coolant temperature 63 °C
Long Term Fuel Trim - Bank 1 4 %
Short Term Fuel Trim - Bank 2 -1 %
Long Term Fuel Trim - Bank 2 5 %
Vehicle speed sensor 67 km/h
Ignition Timing Advance for #1 Cylinder 42 °
Intake Air Temperature 18 °C
Absolute Throttle Position 18 %
Barometric Pressure 980 kPa
Relative Throttle Position 5 %
Ambient air temperature 4 °C
Absolute Throttle Position B 17 %
Commanded Throttle Actuator Control 7 %
Fuel system 1 status 147F
Engine RPM 2432 rpm
Air Flow Rate from Mass Air Flow Sensor 20 g/s
Absolute Load Value 51 %
Total operating time (first occurrence) 748.7 h
Total mileage (first occurrence) 36192 km
P0420
Bank 1 catalytic converter system insufficient effect
Warning light off
Fault path num 29440
FLC/HLC state 00
Fault check state 0D
FCM line status 10
Error Path Status 768
MIL on counter 2
MIL off counter 2
Clear counter 40
Frequency counter 3
Calculated LOAD value 35 %
Engine coolant temperature 87 °C
Short Term Fuel Trim - Bank 1 4 %
Long Term Fuel Trim - Bank 1 2 %
Short Term Fuel Trim - Bank 2 2 %
Long Term Fuel Trim - Bank 2 3 %
Vehicle speed sensor 93 km/h
Ignition Timing Advance for #1 Cylinder 41 °
Intake Air Temperature 31 °C
Absolute Throttle Position 19 %
Relative Throttle Position 7 %
Ambient air temperature 21 °C
Absolute Throttle Position B 18 %
Commanded Throttle Actuator Control 9 %
Fuel system 1 status 197F
Engine RPM 2304 rpm
Air Flow Rate from Mass Air Flow Sensor 26 g/s
Absolute Load Value 55 %
Total operating time (first occurrence) 750.2 h
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
Yogi911
Sep 9, 2015 08:20 PM
