958 oil fill port
Guys,
Can someone tell me where the oil fill port is on Cayenne 958. I can't seem to find it. 958 doesnt have the fill port on the pan..it's somewhere on the driver's side of the tranny I read somewhere... |
The fill port is located on the passenger side on top of the transmission. As I recall, it requires a hex head wrench to remove. A mirror will make locating it much easier. You can use a hand pump on the transmission fluid bottle to refill the transmission. Just be sure you replace exactly the amount that you remove.
Mine took about 6 liters. |
Originally Posted by lurchphil
(Post 4512995)
Originally Posted by Nixer
(Post 4514627)
Thanks! I used the drain port to fill per the workshop manual. Used garden sprayer and VAS6262/2 adapter. My car took about 5 liters cold fill.. I haven't found an infrared temperature reader to top off yet. I read that only PIWIS can read ATF temperature on 958..
I'm kinda late to the party but a Durametric will also show the temp. You may actually be overfilling without checking it at operating temp. |
958 ATF Used to Fill?
What ATF did you guys end up using in each of your fills?
Motul Multi ATF About 6.5 quarts.
