Cayenne - Low Beam OFF, High Beam ON Driver side
2008 Cayenne GTS, I am receiving a dipped beam error and the low beam on the drivers side is currently out, however the high beam still works on this side. I switched the low beam bulb from the driver side to the passenger side and determined that the bulb did work on the passenger side. And the bulb from the passenger side, did not work on the driver side. So it's not a bulb issue. I don't believe it's a Harness issue as the high beam is still working on this side....right? Any help to steer me in the right direction would be very very much appreciated!!! THANKS!
