Notices
911 1964- to current Porsche 911, from the air-cooled days to the current 997
Wevo Engine Mounts For Your Porsche 911!
Old Jun 23, 2015 | 05:05 PM
PelicanParts.com's Avatar
PelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond repute
Brought To You By Pelican Parts!
The WEVO Semi-Solid Engine Mount is the first non-solid aftermarket engine mount developed specifically for Porsche 911 applications (1965-89). Factory rubber mounts allow too much deflection, causing drivability to feel somewhat imprecise. Solid aftermarket mounts increase responsiveness by fixing the engine location, but the metal-to-metal contact between the chassis and the engine is almost too rigid - which could ultimately affect the reliability of the vehicle.
Instead of compliant rubber or solid metal, the WEVO SS Engine Mounts utilize special elastomeric pillows to absorb vibration while minimizing drivetrain deflection. This exclusive design is thus the best of both worlds - providing a near-rigid engine mounting system while maintaining a quiet and comfortable ride. Use them for the street or the track - they're the most advanced engine mounts you can install on your 911!
This WEVO SS Engine Mount is suited to the following applications:
911 1965–89 Engine rear cross beam – 2 units
911 1972–86 Transmission mount – 2 units
930 1976–89 Engine rear cross beam – 2 units
The “Black" Pillows are 15 points softer on the Shore “A" scale for durometer readings than the original "Blue" Pillows. The Black pillows function in the same way as the Blue pillows – although they allow slightly more deflection under similar loads – the advantage is lower noise transfer through the SS mount module.
Black pillows are recommended for street use or occasional track use. For pure track work, Blue pillows are recommended. Blue and Black pillows can also be mixed in any combination – including mixing them within a single mount body. This provides you with the flexibility to suit your exact needs.
Note: The SS Engine Mounts are installed using original hardware and have a gold anodized finish similar in appearance to the gold zinc plated factory parts. Each mount is sold individually.
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Parts | DIY Help | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
COBB Tuning
Jan 1, 2025 09:02 AM
2lflat4
Nov 18, 2019 05:05 PM
PenguiN
Oct 26, 2018 07:23 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
