Notices
911 1964- to current Porsche 911, from the air-cooled days to the current 997
Which oil for old Porsche 911 ?
Old Sep 16, 2015 | 03:11 AM
Racerfanny's Avatar
Racerfanny is infamous around these parts
Hi. I have a 1987 911 Carerra 3.2 (non-turbo). I have always used Fully Synthetic 5-40 without problems, as was the recommendation of the previous owner (an engineer,who had re-built the engine).
However speaking to fellow owners, it has been suggested that this is a bad idea and the car should be running on something 'thicker' such as the old multigrade 20/50.
This is indeed what is 'recommended' in the original handbook - but bearing in mind 'Fully Synthetic' oils were not available 27 yrs ago !
So...What should I be using ? Informed answers appreciated.
Old Sep 16, 2015 | 12:01 PM
Upier's Avatar
Upier is infamous around these parts
I switched to Brad Penn oil. Made for older air cooled cars. Runs cool and uses less oil.
Old Sep 16, 2015 | 09:41 PM
Jackracing's Avatar
Jackracing is infamous around these parts
Is there a problem you are trying to solve? Does the car use excessive amounts of oil? If not, stick with the synthetic. It provides better protection on start up and is thermally a lot more stable, this is something that could be important in an air cooled engine.
Old Sep 17, 2015 | 07:31 AM
Upier's Avatar
No problems just observations. Brad Penn oil is a semi sinthetic oil.
Features
Semi-synthetic
Deliver excellent shock load and high temperature protection
Reduce internal friction for increased horsepower output
Contains strong detergent, dispersant and ZDDP anti-wear additives to help protect critical engine parts
If you look at the 100s of oil threads it is recommended often with no issues identified.
Old Oct 11, 2015 | 06:12 AM
mibi's Avatar
mibi is infamous around these parts
use the 10w-60 porsche classic oil.
great broad coverage for cold starts and long hot runs.
Old Oct 14, 2015 | 02:38 AM
Racerfanny's Avatar
Thanks for all of you.
Old Jan 8, 2016 | 08:37 PM
Dapainta's Avatar
Dapainta has a spectacular aura aboutDapainta has a spectacular aura about
Just seeing this thread... I have had total faith in Rotella for my air cooled motors. It keeps them well lubed and resists "seeping" synthetics can encourage.
COBB Tuning
Jan 1, 2025 09:02 AM
2lflat4
Nov 18, 2019 05:05 PM
PenguiN
Oct 26, 2018 07:23 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
