924/944/951/968
Replacing the worn, stock shift lever.
Old Jul 20, 2009 | 08:25 PM
racerbvd's Avatar
racerbvd has a reputation beyond reputeracerbvd has a reputation beyond reputeracerbvd has a reputation beyond reputeracerbvd has a reputation beyond reputeracerbvd has a reputation beyond reputeracerbvd has a reputation beyond reputeracerbvd has a reputation beyond reputeracerbvd has a reputation beyond reputeracerbvd has a reputation beyond reputeracerbvd has a reputation beyond reputeracerbvd has a reputation beyond repute
I'm sure this has been covered before, but just in case.
1st, lift the leather boot
2nd, lift the rubber boot then remove the C clip from the shift **** and all comes right off.
Exposed shifter.
3rd Remove C clip from shift pin and the shift tube slides right off.
This is the lever we are replacing the stock one with; it is aluminum with adj. shift throw. Tools need are a Flat head Screw driver, 4mm Allen wrench & 13mm socket.
4th, Use the 13mm socket to remove the 2 bolds holding the shifter in place.
This is what it looks like out.
Old Jul 20, 2009 | 08:27 PM
racerbvd's Avatar
5th, Push the base up the shift lever to pop the Plastic cup holding the base of the lever, now the lever will pop right out.
6th Pop the new lever in the cup just as you removed the old one. Bolt the base back in..
7th Reconnect the shift to the new pin, replace the C clip.
This is what it should look like.
8th Replace the rubber boot, add the shift **** of your choice and you are done..
Notice the end of the shift pin that is the wear that causes sticky shifting.
Old Jul 23, 2009 | 03:01 PM
CorsePerVita's Avatar
CorsePerVita is infamous around these parts
Nice pictorial!
Old Sep 3, 2009 | 08:30 PM
racerbvd's Avatar
Thanks....
MAcarbon
Mar 6, 2017 08:16 AM
MAcarbon
Aug 24, 2015 03:26 PM
MAcarbon
Aug 20, 2015 03:02 PM
MAcarbon
Aug 19, 2015 06:22 PM
MAcarbon
Aug 19, 2015 04:52 PM
