Fabspeed 944 Turbo 3.0” and 4.0” Full Exhaust Package
Old Feb 5, 2009 | 01:26 PM
Fabspeed Motorsport's Avatar
Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !
Fabspeed wants to remind everyone with a Porsche 951/ 944 Turbo about our exhaust package that is available. The package consists of the 3.0” Catbypass pipe with downtube which makes 20+HP alone, Turbo top outlet pipe and a 3.0” or 4.0” catback Maxflo exhaust to increase boost and reduce backpressure off the turbo. This is a required upgrade for all 944 turbo street and track cars. We have a 3.0” and 4.0” version to suite all different and modified cars with higher horsepower motors. If you are looking for a new exhaust that sounds awesome, makes horsepower and reduces Turbo lag, this is the option you want. The exhaust tip will fill in the factory bumper outlet much better and look more aggressive.
  • Fits All 951/ 944 Turbo cars 1986-1990
  • Dyno Results show a 25-45+ HP Increase and +.15 more boost with the full package.
  • Simple and easy bolt-on installation
  • Saves over 20 lbs from the rear of your 944T and significantly increases horsepower that you can feel. Strongest and finest high performance exhaust system available for all 944 Turbo cars worldwide.
  • 14 - 16 gauge T304 Stainless Steel- Much stronger, better quality and guaranteed to be the finest quality available.
  • Throaty and deep at idle and medium speeds, but a strong and deep sports car sound when you floor it and go up through the gears!
  • 944 Turbo 3.0" and 4.0" Exhaust Video (http://www.fabspeed.com/944Turbo.html)
Visit www.fabspeed.com for more information and product videos for the 944 Turbo and to place an order. Please make sure to mention this code (AK6FS01) to receive the 6speed member discount when placing your order.
The 6speed member price for the 944T 3.0” Exhaust Package is $1450 and the 4.0” Exhaust package is $1495
All parts are in stock and ready to ship. We ship internationally as well. Feel free to PM or email me Alex@fabspeed.com directly with any questions you might have.
3.0" Catback Maxflo Exhaust
3.0" Catbypass Pipe with Downtube and optional Sport Race Cat
4.0" Catback Maxflo Exhaust
Old Feb 6, 2009 | 08:29 AM
IAPorscheDoc's Avatar
IAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond repute
I run a 3" Fabspeed on my car and it is amazing. Also, don't forget, Fabspeed has replacement downpipes (off the turbo). It is becoming more common that the inner walls are collapsing on the stock downpipes, and block the proper exhaust flow. If you are going to have your turbo off, might think about picking up a downpipe and replacing it!
Old Feb 9, 2009 | 02:10 PM
Thanks PorscheDoc for the great feedback, that technical information is important and most owners dont realize something like that happens. Its a nice upgrade and well worth it when doing work with the turbo to make the installation easier. We have the 944 Turbo Top pipes in stock and we are doing a $250 special till March 1st. PM or email for more information.
Thanks,
Alex@fabspeed
Old Feb 13, 2009 | 04:11 PM
Thanks,
Alex@fabspeed
That is a great deal on the downpipe, well worth it, and a no brainer when doing any turbo work. The question isn't if the inner wall will collapse, it is when.
A stock downpipe failure. Almost every downpipe I pull, the inner wall is cracked around the edges.
And the Fabspeed Downpipe.
Old Feb 19, 2009 | 07:28 PM
nize's Avatar
nize is just really nicenize is just really nicenize is just really nicenize is just really nicenize is just really nice
is the flange where this exhaust mates to the downpipe a true 3", or does it taper down to fit the stock downpipe?
Old Feb 26, 2009 | 09:48 AM
Hi Nize, ours is a full 3.0" system but it will bolt directly to the downpipe because they use the same type of flange, but the size of the tubing may be a bit smaller on the factory piece compared to our full 3.0" setup.
Alex@fabspeed
Old Feb 26, 2009 | 10:06 AM
nize's Avatar
Alex@fabspeed
hi alex, thanks for the response. can you explain why it looks like it is tapered down in the photo? i've attached a photo to explain.
also, can you provide a detailed photo of this section? thanks!
Old Feb 26, 2009 | 11:53 AM
It does taper down to fit the stock downpipe (2.75" IIRC). It is not smaller than the stock downpipe diameter though so it isn't a restriction unless you are running a full 3" downpipe, and then goes up to 3" immediately after that neck that you see in the picture.
Old Feb 26, 2009 | 12:46 PM
nize's Avatar
thanks for the clarification.
do you know if fabspeed offers a true end-to-end 3" exhaust system? thanks again.
Old Feb 26, 2009 | 12:55 PM
Hi Nize, our entire exhaust system is available in both full 3.0" and 4.0". We came out with the Turbo top pipe at a later time and this is why our downpipe tapers down in the beginning. The design will not make major difference in the restriction but If you are interested in the system, I can have one of my fabricators make the change on the pipe.
Thanks,
Alex@fabspeed
Old Feb 26, 2009 | 01:05 PM
nize's Avatar
hi alex, thanks again for the response and clarification.
i already have the lindsey 3" exhaust which has the exact same restriction taper at the downpipe flange.
what i am looking for is a true turbo-back 3" system including the downpipe.
what i really need is only a 3" downpipe and a true 3" downpipe-to-cat section (without the taper), but if i have to buy the whole system to get an end-to-end 3" from the turbo back, i probably will.
is this something you have available? i took a look around your site but do not see any 3" downpipe offering. thanks.
Old Feb 26, 2009 | 04:22 PM
Nize,
Their downpipe is a replacement for the stock piece, size is 2 3/4".
Old Feb 27, 2009 | 06:39 AM
Nize, PM sent.
Thanks PorscheDoc.
Old Aug 9, 2009 | 09:49 PM
spooled951's Avatar
spooled951 is infamous around these parts
amazing exhaust
Fabspeed Motorsport
Aug 26, 2015 11:15 AM
Vrseis
Aug 20, 2015 07:41 AM
oddjob142
Aug 19, 2015 12:27 PM
Fabspeed Motorsport
Aug 18, 2015 03:24 PM
