FVD Ignition Sensor Holder min.93 Octane Rating
Questions for a 91 964 Turbo ; -Should there be any concern about engine knock by increasing the ignition timing across the rpm range by 6.5 degrees? -Would 93 octane be enough to prevent any risks on a 1+bar setup? -Installing Knocklink or an aftermarket knock sensor may be necessary? |
Originally Posted by marcvip
(Post 2104046)
Apparently the oem ignition advance is 40 deg from 3000 rpm upwards at 400 mbar ( no boost) and 21 deg. at 1.750 mbar (boost). It is an increase of 6.5 degrees across the rpm band. Can anyone with tuning experience chime in?
bump
