87 Turbo
Old Jun 17, 2005 | 10:48 AM
hoonut's Avatar
hoonut is infamous around these parts
87 Turbo
Having a problem with my newly aquired 87 811 turbo. It runs great but will but out occasionally and usually starts right back up. Replaced the fuel pump relay and it was still doing the cutout thing. Now it just wont start unless I jumper over the fuel pump relay and then it fires right up. But the relay does not appear to be the issue. Has anyone had this issue with a previous car? Thanks.
Old Jun 17, 2005 | 11:12 AM
PorschePhd's Avatar
Check the overboost switch. It is a white wire. They are known for going bad. Make sure the car is not over boosting first. If not then ground the wire down. If the problem stops then replace the switch.
Old Jun 19, 2005 | 09:53 AM
buddyg's Avatar
You see the problem is you bought an 811 turbo, you really should have gotten a 911 turbo!
Old Jun 19, 2005 | 10:25 AM
BAD ASH's Avatar
BAD ASH is infamous around these parts
good luck fixing it.
Old Jun 21, 2005 | 01:32 PM
Arnie's Avatar
Arnie is infamous around these parts
Check the fuse box. I had the same problem. There are 2 fuses that run the system. They have a tendency to overheat. I had the fuse box rewired which cured the problem
Arnie
Old Jun 21, 2005 | 05:44 PM
Gator Smiles's Avatar
Gator Smiles is infamous around these parts
I am not an expert but remember my dad's 86 with a similar sounding problem (ten years ago). I remember him jumping the relays as well to just get things going. It came down to replacing BOTH fuel pumps. I believe there is one at the front and one at the rear.
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
Christian
Aug 24, 2015 12:56 PM
johnny.dangerous
Aug 21, 2015 10:48 AM
PelicanParts.com
Aug 20, 2015 02:57 PM
