CR-1 issue 94 Turbo
Old Nov 29, 2013 | 01:33 PM
KC Phil's Avatar
KC Phil is infamous around these parts
CR-1 issue 94 Turbo
Update to earlier post. Had to pull the cd changer to send out for repair. I sent the unit to Factory Radio Service & Repair in Rancho Cucamonga, Ca--they had also repaired the radio. Unit is now back and installed, working like new. I'm excited as this helps to keep my car in its original condition. The service is fast and very reasonable. If anyone has audio issues you should send an email to John at factoryradioservice@gmail.com
Old Dec 2, 2013 | 02:54 PM
ECS Tuning - Porsche's Avatar
Glad to see you got everything worked out. Post a few pictures of your car when you get a chance. Would love to see it
Old Dec 2, 2013 | 08:02 PM
KC Phil's Avatar
CR-1 Issue
Thanks again for your help. I followed the instructions but the changer just would not free up. The repair company replaced a couple micro processers and few other things plus there was a cd stuck in the unit--which I could not see. I sent the shop a copy of the bulletin you provided me. Again thank you. Works like new now. I will get photos--took some but not the best. The car is Midnight Blue Metallic with tan leather.
Old Oct 9, 2014 | 05:20 AM
Ansari443's Avatar
Ansari443 is infamous around these parts
Small but mighty, the Neodymium super magnet in an ECS Tuning magnetic drain plug collects wandering metallic particles and holds them captive until they can be wiped away at the next oil change.
Next oil change? Install an ounce of prevention with a drain plug that catches and holds ferrous particles with an iron grip, before they can cause expensive engine damage. Complete with drain plug sealing ring, the ECS drain plug accepts standard aluminum sealing rings for your convenience.
COBB Tuning
Jan 1, 2025 09:02 AM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
993 Turbo Vendor Classifieds
Aug 18, 2015 03:55 PM
PelicanParts.com
991 Turbo Vendor Classifieds
Aug 18, 2015 03:47 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 18, 2015 03:43 PM
