Increase 964 chassis stability and enhance shifter feel and accuracy
Old Nov 27, 2013 | 12:00 PM
Function-First's Avatar
Function-First is infamous around these parts
Introducing new 6speedonline site sponsor: FUNCTION-FIRST Performance
TRANSMISSION MOUNT INSERT
Fitment: 964/993 2WD (AWD version coming soon)
The OEM transmission mount was designed for ride comfort and is prone to sagging and tearing – above all, it is a detriment to performance. Its empty voids allow for too much transmission movement, resulting in sloppy handling, numbed responsiveness, and imprecise shifting. Racecars utilize a solid metal mount to mediate this, which is impractical for street use as it transfers extreme noise and vibration into the cabin.
So how do you achieve the benefits of a solid mount while retaining daily drivability? Function-First Performance offers the only available solution that is both economical and easy to install. Our durable urethane rubber insert simply slips in to fill and fortify the empty voids of the OEM mount - prevent premature bushing wear and undesirable transmission movement, all while transmitting minimal added noise and vibration.
The result? Handling is taut and predictable; power delivery is immediate and smooth; gear changes are crisp and confident.
Installation can be completed with basic hand tools in about one hour. Dropping the transmission to press out the stock transmission mount bushing is NOT necessary, so you can easily return your car to stock condition when selling!
Please click here to order!
Jul 29, 2019 11:13 AM
Sep 10, 2015 03:20 PM
