:: ECS Tuning :: Schwaben European Essentials Tool Set | DIY Gold!!
You've hit the jackpot with the Schwaben European Essentials Tool Set. Never again will you be cursing the unique fasteners on your European automobile. Instead, you'll take to the task like a conquistador of cars. The garage is your El Dorado.
Featuring swivel-head triple-square bits, Torx screwdrivers, one hundred specialty fasteners and the sturdiest screwdriver set you'll lay hands on, this kit will make you feel like a king. Each tool rests in its own place in molded cases, helping you keep track of your investment. The Schwaben Essentials kit is worth its weight in gold.
Click Here for more information
This Universal European Tool Kit includes the following:
- Torx Screwdriver Kit - 6 Pieces (Sizes included: T10, T15, T20, T25, T27, & T30. Perfect for removing door and dashboard panels, interior trim, and smaller underhood components. )
- Swivel Head Triple Square Driver Kit - 4 Pieces (Set of four 3/8 drivers in M6, M8, M10, and M12 sizes. Perfect for working around corners in those hard to reach spots.)
- Specialty Bit Kit - 100 Pieces (100 piece torx & hex bit kit to fit a wide assortment of automotive fasteners. Made of hardened Chrome Vanadium steel, packaged in a handy blow molded case.)
- Go-Through Screwdriver Kit - 6 Pieces (Kit includes durable slotted & phillips head nickel-chromoly screwdrivers with hardened shafts that extend the entire length of the driver.)
Don't delay any longer and order your kit TODAY!!
The Schwaben 100-piece specialty bit kit includes bits to fit a wide assortment of automotive fasteners, including tamper-proof Torx® and hex bits. Breeze through repairs knowing you can remove odd specialty fasteners with ease.
These bits are made of hardened Chrome Vanadium steel for years of dependable use. Packaged in a handy blow molded case with individually marked bit slots for easy organization.
ECS Tuning - VW
Aug 20, 2015 02:01 PM
ECS Tuning - VW
Aug 19, 2015 02:36 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
ECS Tuning - VW
Aug 19, 2015 01:23 PM
ECS Tuning - VW
Aug 19, 2015 11:08 AM
