991 Turbo Vendor Classifieds
Cat Bypass Pipes-For Off-Road Use Only
Old Oct 13, 2016 | 11:12 AM
Staff@WORLD's Avatar
Staff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to behold
For those 991 turbo owners that are going to the track and want to remove the catalyst for racing purposes we have a cat-bypass pipe available. It's an easy bolt-on part that can be used with the stock muffler or a slip-on aftermarket muffler line an Akrapovic.
DYNO CHART WITH CAT-BYPASS, STOCK MUFFLER AND STOCK TUNE-
You will see that the car comes on power much quicker with the cat-bypass pipes. You will also see that the fuel mixture runs much leaner which means that their is a lot of extra power on the table when combined with a tune.
DYNO CHART WITH CAT-BYPASS, STOCK MUFFLER AND A TUNE-
Now you can see just how much power a tune can make with the cat-bypass pipes. You will notice that the motor still comes up on power much earlier but it continues to make great power through the entire power band.
THESE ARE FOR TRACK USE ONLY AND ARE NOT LEGAL TO USE ON THE STREET IN ANY OF THE 50 STATES. ALSO AVAILABLE FOR CHEAP WORLDWIDE DELIVERY.
PURCHASE THESE CAT-BYPASS PIPES WITH THIS LINK
Old Sep 11, 2017 | 12:50 PM
This is the best bang for your buck exhaust upgrade for those guys that are looking for an off-road track set up.
It adds power and sound.
Old Sep 21, 2017 | 12:05 PM
M3 S3-R's Avatar
M3 S3-R is a jewel in the roughM3 S3-R is a jewel in the roughM3 S3-R is a jewel in the rough
If you install these cat delete pipes will the car throw any check engine or other warning lights on the dash.
Old Sep 21, 2017 | 12:39 PM
It will. If you want to avoid seeing the check engine light you will need to add a tune.
louisifis
Nov 2, 2020 01:16 PM
pikajew
Aug 28, 2016 04:09 AM
tigerwoods2002
Aug 20, 2016 09:14 AM
lilo1980
Bentley
Aug 12, 2016 02:58 AM
