Turbo /S MFD information
Old Feb 9, 2014 | 06:12 PM
sitecap's Avatar
sitecap is infamous around these parts
What performance data appears on the MFD screen next to the tach? I know you can have a mini GPS map, tire pressure, time/date, oil & coolant temps, audio source info, phone info, etc.
But I've seen some pics with something that looks like HP or torque graph or something showing boost???
Old Feb 9, 2014 | 10:20 PM
Dubai_TT's Avatar
Dubai_TT is just really niceDubai_TT is just really niceDubai_TT is just really niceDubai_TT is just really nice
Originally Posted by sitecap
What performance data appears on the MFD screen next to the tach? I know you can have a mini GPS map, tire pressure, time/date, oil & coolant temps, audio source info, phone info, etc. But I've seen some pics with something that looks like HP or torque graph or something showing boost???
You can have also have lap time info, torque curve, g-meter and power split (front/rear tires)
Old Feb 10, 2014 | 04:29 AM
sitecap's Avatar
What does the torque curve screen look like and what info does it tell you?
I would assume it shows you current torque being produced from RPM - or does it actually measure torque at the wheel?
Old Feb 10, 2014 | 09:18 AM
Dubai_TT's Avatar
What does the torque curve screen look like and what info does it tell you? I would assume it shows you current torque being produced from RPM - or does it actually measure torque at the wheel?
Cant take a photo of it until next week as my car getting a clear bra put on, but im sure other members can show you. Basically its like a graph showing the rpm range with a dot that moves along it going up to indicate where the torque delivery is at that given time. Its a cool feature.
About your second query, im not versed in the intricate details relating to this, but my guess would be that it shows torque produced by engine.
Old Feb 10, 2014 | 06:59 PM
TAch Miami's Avatar
TAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond repute
The torque display has horizontal rpm markings but there are no vertical lb/ft markings. The moving dot is a position on the graph at an indicated RPM and at some proportion between 0 and the maximum torque, whether measured at the wheels or the crank.
Aug 21, 2015 06:34 AM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
