Launch Control ?
Old Mar 21, 2015 | 10:03 AM
sdg1871's Avatar
sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !
Originally Posted by CPIGUY
This video of my white 991 TTS is using launch control with TC off. No squealing tires, no loss of control, just raw acceleration!
At the time of the race was your car GIAC Stage 1 or 2?
Old Mar 21, 2015 | 10:10 AM
CPIGUY's Avatar
CPIGUY has a reputation beyond reputeCPIGUY has a reputation beyond reputeCPIGUY has a reputation beyond reputeCPIGUY has a reputation beyond reputeCPIGUY has a reputation beyond reputeCPIGUY has a reputation beyond reputeCPIGUY has a reputation beyond reputeCPIGUY has a reputation beyond reputeCPIGUY has a reputation beyond reputeCPIGUY has a reputation beyond reputeCPIGUY has a reputation beyond repute
Stage 1
Old Mar 21, 2015 | 10:22 AM
sdg1871's Avatar
Stage 1
I see. Dominant even on just Stage 1
Old Mar 21, 2015 | 11:05 AM
CPIGUY's Avatar
Yeah, never lost a race the entire day.
Old Mar 21, 2015 | 11:45 AM
sdg1871's Avatar
Nice! Were you on pump gas or race gas?
Old Mar 21, 2015 | 12:36 PM
CPIGUY's Avatar
Race 100
Old Mar 21, 2015 | 12:56 PM
BigRich's Avatar
BigRich has much to be proud ofBigRich has much to be proud ofBigRich has much to be proud ofBigRich has much to be proud ofBigRich has much to be proud ofBigRich has much to be proud ofBigRich has much to be proud ofBigRich has much to be proud of
Could someone give me the proper steps for switching GIAC flash to race. IE do I fill up with race fuel then start the car, hook in the loader and press race or do I it with the key in the on position but no engine on? Any help/tips would be appreciated!
Old Mar 21, 2015 | 02:12 PM
CPIGUY's Avatar
Fill with race gas. Turn key to on but do not start. Press read. It should flash and stop on pump. Press race. It should start flashing and stop on race. That's it.
Old Mar 21, 2015 | 03:30 PM
BigRich's Avatar
Thank you!
Old Mar 21, 2015 | 03:32 PM
BigRich's Avatar
BTW do you just run the gas down to a range of 20 miles or so then fill with race fuel?
Old Mar 21, 2015 | 09:17 PM
CPIGUY's Avatar
Thumbs up
yep
Old Mar 22, 2015 | 08:51 AM
enzom's Avatar
enzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond reputeenzom has a reputation beyond repute
Slightly OT - Do you need to cycle through a tank of 100 before running the 100 tune? In other words, if you are at half a tank of 93 and fill up with 100, you are running a mix that is less than 100. I would think that you would need to run your tank back down to 1/4 and fill with 100 again until it is safe to run the 100 tune.
Is the 100 tune sophisticated enough to make adjustments if the actual gas in the tank is less than 100? I have a station near me (like 5 miles) that sells 100, but I wonder how often they run through that gas and how fresh it is.
Old Mar 22, 2015 | 09:40 AM
CPIGUY's Avatar
For the best and safest results, you want your tank to be completely empty when you fill up with race gas. I'm not sure running a blend will hurt anything, but it will definitely produce suboptimal results.
Old Mar 23, 2015 | 07:47 AM
Karl911's Avatar
Karl911 has much to be proud ofKarl911 has much to be proud ofKarl911 has much to be proud ofKarl911 has much to be proud ofKarl911 has much to be proud ofKarl911 has much to be proud ofKarl911 has much to be proud ofKarl911 has much to be proud ofKarl911 has much to be proud ofKarl911 has much to be proud of
I just almost run out of gas, then top it off with 100 OCT
Rguy
Apr 12, 2020 11:11 PM
rohnin
Sep 7, 2015 01:10 PM
MrJoshua
Sep 6, 2015 02:06 PM
