New 991 TTS - Oerding911
#35
Thank you, it definitely adds some uniqueness among the other Turbos out there. Eric made me a package deal with wheels and lowering springs.. i would contact him for wheel pricing specifically. They are one of it not the biggest BBS wheel dealers here in Socal
#37
I agree! mine is getting louder and louder as the miles rack up! did you have any problems with the 'sport' setting not working correctly? mine had issues as the back pressure sensor got burnt by the exhaust very early on so the cabling had to be rerouted to avoid the hot pipes. so I had to leave the valves open all the time.... fixed now, but prefer the sport setting where the valves open when back pressure builds up..
#39
You are correct. Techart is more conservative, and tends to have a slight rake in the rear. The h&r springs for the turbo are just to low IMO.
#40
#43
You going to the HRE open house June 4? I've been out of the country for a while but should be back sometime before then. Look forward to seeing your car with the tech art / bbs combo.
#44
Thanks so much UT! I will work on updating this thread more often
#45
Yes, i will be doing a caravan there as well if you would like to join in..
