Tow hook license plate frame recommendations
Old Feb 14, 2016 | 08:56 PM
ioman's Avatar
ioman is infamous around these parts
I know there are a lot of threads on this here, but it doesn't appear to be a specific recommendation.
It's very common for the police to give tickets for not having a front license plate in the town I live in and I would rather not drill holes into my bumper.
Is there a tow hook license plate solution that will not interfere with my parking sensors that anyone would recommend?
Thanks everyone, and apologies in advance if there is a clear thread with recommendations on this that I might have missed.
Old Feb 15, 2016 | 03:43 AM
porschespeedjunky's Avatar
porschespeedjunky is a jewel in the roughporschespeedjunky is a jewel in the roughporschespeedjunky is a jewel in the roughporschespeedjunky is a jewel in the rough
No tow hook installation that will still allow the use of the parking sensors. I've exhausted that thread personally. There is another option that you still will have to drill or 3M tape into a location of your bumper. Good luck keeping it on @ excessive speeds.
Old Feb 17, 2016 | 02:49 PM
Visceral's Avatar
Visceral Is a GOD !Visceral Is a GOD !Visceral Is a GOD !Visceral Is a GOD !Visceral Is a GOD !Visceral Is a GOD !Visceral Is a GOD !Visceral Is a GOD !Visceral Is a GOD !Visceral Is a GOD !Visceral Is a GOD !
I use a tow-hook solution that allows parking sensors. I think it looks fine, but others might disagree.
http://www.dynamtechgroup.com/porsch...ate-holder.php
The Drop Mount works well for me both with Active Cruise and parking sensors.
Old Feb 18, 2016 | 12:26 PM
justthebest's Avatar
justthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud of
Can't tell from the picture - is the mount rigid through its length (i.e. does it swing back / forth at all)?
Old Feb 18, 2016 | 02:11 PM
Visceral's Avatar
Yeah, it's rigid insofar as you tighten the screw and put the tow-hook "blank" in as far as it needs to go to be tight.
I once drove through a car-wash with it on absent-mindedly, and it just ended up turned slightly. The newly-blocked parking sensor let me know
Old Feb 18, 2016 | 02:12 PM
Visceral's Avatar
Also, I spray-painted the whole mount black with heavy-duty Krylon. The raw-aluminum look wasn't right for my car.
Old Feb 18, 2016 | 02:20 PM
verinnal's Avatar
verinnal has a brilliant futureverinnal has a brilliant futureverinnal has a brilliant futureverinnal has a brilliant futureverinnal has a brilliant futureverinnal has a brilliant futureverinnal has a brilliant futureverinnal has a brilliant futureverinnal has a brilliant futureverinnal has a brilliant futureverinnal has a brilliant future
While I realize that the OP had a very specific question as it pertains to tow-hooks vs other mount types, however I'll just ask this anyway.
Have you considered making your own, invisible license plate holder? I did this for my car by using super strong neodymium magnets, some thin foam, and the Porsche license plate bracket. It involves taking off the front bumper, however that is tremendously easy, and the end result is the ability to just touch the license plate to your bumper and drive away. The foam behind the bracket would protect it from scratches. Anyhoo, that's my two cents and I realize this has nothing to do with tow hooks.
macksamus
Mar 14, 2017 06:01 PM
Dan GSR
Feb 10, 2016 08:57 AM
