Dyno with OTS Stage 1 Cobb tune
Old Sep 3, 2016 | 04:24 AM
nabizzy's Avatar
nabizzy is a name known to allnabizzy is a name known to allnabizzy is a name known to allnabizzy is a name known to allnabizzy is a name known to allnabizzy is a name known to all
Ended up dynoing the car yesterday in this Texas heat
Got some heat soak but here are initial numbers with the stage 1 tune alone
Sam has been guiding me along the way, and has even offered to help with data logs even though I did not buy the Cobb from him. He has been a real joy to deal with.
Old Sep 3, 2016 | 05:00 AM
sdg1871's Avatar
sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !sdg1871 Is a GOD !
Good numbers. Get the upgraded Intercoolers to stop the heat soak.
Old Sep 3, 2016 | 01:02 PM
SamboTT@ByDesign's Avatar
Cheers Nab!
Here for whatever you need. Now you have a good base to refer to as you go up the crack pipe ladder
Let me know how either of those exhaust options pan out. That will open her up!
Old Sep 3, 2016 | 04:55 PM
Turbo8765's Avatar
Turbo8765 is infamous around these parts
What was the baseline?
Old Sep 3, 2016 | 05:13 PM
nabizzy's Avatar
being the genius I am, i failed to take the cobb to stage 0 in order to get a baseline run.
Old Sep 6, 2016 | 09:57 AM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
Curious, where in TX did you dyno? I have some customers in TX that are looking for a local dyno but it seems there aren't that many around.
Old Sep 6, 2016 | 10:13 AM
tommyboy214's Avatar
tommyboy214 Is a GOD !tommyboy214 Is a GOD !tommyboy214 Is a GOD !tommyboy214 Is a GOD !tommyboy214 Is a GOD !tommyboy214 Is a GOD !tommyboy214 Is a GOD !tommyboy214 Is a GOD !tommyboy214 Is a GOD !tommyboy214 Is a GOD !tommyboy214 Is a GOD !
I have been to Cobb in Plano and I know they have a dyno there.
Old Sep 6, 2016 | 11:52 AM
nabizzy's Avatar
I went to eurocharged in Houston TX
Old Sep 6, 2016 | 03:47 PM
achenator's Avatar
achenator is a jewel in the roughachenator is a jewel in the roughachenator is a jewel in the rough
Shouldn't these cars make more than 48x whp stock? What am I missing here? I was told around 500 stock for a 991 Turbo S? Am i wrong?
Old Sep 6, 2016 | 08:56 PM
nabizzy's Avatar
Every dyno reads differently and numbers are based on a lot of factors.
Old Sep 6, 2016 | 09:15 PM
sdg1871's Avatar
Not surprised. 40-50 wheel hp is typical for just a tune. For big power you need to remove the restrictive stock cats and get high flow cars or catless. And more Even more you need to upgrade the puny stock intercoolers
the tuners can only turn up the wick so much before the concern of high exhaust gas temps frying the stock cats come into play.
Old Sep 6, 2016 | 10:13 PM
achenator's Avatar
Maybe Im just reading this graph wrong. What is this car making?
Old Sep 6, 2016 | 10:45 PM
sdg1871's Avatar
Best run shows 483 wheel hp on Dynojet which is 579 hp at the crank assuming a 20 percent drivetrain loss. The gain from stock to tune only is not great on the 991'Turbo. Car really needs high flow cats or no cats to allow the tuner to unlock the power
Old Sep 7, 2016 | 08:20 AM
480-soemthing is even on the higher side of what we usually see from these cars in stock form.
Normally, we see something in the 460's, maybe low 470's. However there are some cars that are just stronger than others for whatever reason.
Old Sep 7, 2016 | 10:13 AM
nabizzy's Avatar
This car was dynoed with the cobb stage 1 off the shelf tune and made about 485WHP and 600 WTQ
HP number was a bit low, but I didn't expect much HP gains without supporting modifications, I was told to expect torque gain, and with 20% loss 600WTQ is about 720 crank torque, which is a gain of over 150 from stock if you factor in the overboost
