Turbo Tom hits the strip (video)
Old Sep 24, 2016 | 06:06 AM
Td33's Avatar
Td33 has much to be proud ofTd33 has much to be proud ofTd33 has much to be proud ofTd33 has much to be proud ofTd33 has much to be proud ofTd33 has much to be proud ofTd33 has much to be proud ofTd33 has much to be proud ofTd33 has much to be proud of
Just kicking a## and taking names! No surprise with the team that you worked with.
Old Sep 24, 2016 | 09:56 AM
shifter_'s Avatar
shifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond repute
Originally Posted by trader247
Dude, that is sick....
Are you doing the burn out water pit or driving around it, being as we are all well drive?
Again, congrats....
Drive around the water. Back up almost to it. Launch with PSM off to spin the tires and clean off rocks.
Old Sep 24, 2016 | 01:12 PM
trader247's Avatar
trader247 has much to be proud oftrader247 has much to be proud oftrader247 has much to be proud oftrader247 has much to be proud oftrader247 has much to be proud oftrader247 has much to be proud oftrader247 has much to be proud oftrader247 has much to be proud of
Great idea. In practice does it work pretty well?
Old Sep 24, 2016 | 07:03 PM
Nanook's Avatar
Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !
I'd say the numbers speak for themselves
Old Sep 26, 2016 | 11:58 AM
Markblackwell's Avatar
Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !Markblackwell Is a GOD !
Congratulations great times these cars are so awesome at the track. Get a little better launch and your in the 9's for sure, or get a little lower DA and your there as well.
Old Sep 26, 2016 | 12:02 PM
Nanook's Avatar
Thanks Mark..so close !!
Old Sep 26, 2016 | 12:41 PM
SamboTT@ByDesign's Avatar
Mark that is the no-meth race map. I bet your car would do it easier with the tires and comp exhaust.
But Greg for you it's just a matter of time. What you did in 82% humidity is insane! I can pretty much guarantee you 9's and 142+
Old Sep 26, 2016 | 12:56 PM
Nanook's Avatar
K..I'm holding you to it Sam I luv money back guarantees
Old Sep 26, 2016 | 01:09 PM
It's there for you to do it! Enjoy the ride!
Old Sep 26, 2016 | 01:26 PM
[QUOTE=SamboTT@ByDesign;4564729]Mark that is the no-meth race map. I bet your car would do it easier with the tires and comp exhaust.
Sam next time I go out to the track After I get my numbers im looking for Ill will run no meth and will see what kind of damage we can do!
Old Sep 26, 2016 | 02:12 PM
Fist bump! Upgraded PDK in transit!
Old Sep 26, 2016 | 06:11 PM
shops ready for it! 👊🏻
Old Sep 26, 2016 | 06:17 PM
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
Originally Posted by White991TT
Congrats your car looks mean. Def a 9 sec killer with some seat time and DRs. Your 60' is where you'll find most of it. Upgraded Turbo Stage 4 Cars on Sams bullet proof maps are so fun to drive, consistent and bullet proof. I probably launched 130+ times without one single issue. Is there another 700 rwhp car on the planet this well rounded?
From my research and from all that I have seen....NO!
Old Sep 29, 2016 | 11:28 AM
E-Gear's Avatar
E-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond repute
Great runs homie - very consistent.
You want 9's? Get better 60' times. Not sure what tire psi you ran or how sticky the track was.
Don't be afraid to play with tire psi and if you like, ask the line worker to VHT the starting line for you prior to your pass. Slip him/her a $20 bill when first arrive at track and they'll hook you up with good starting line prep when you come up to make passes. It works for me
Also, you may want to ask Sam to dial back HP (timing - boost) at lower RPM's HP just a tad...I know it is tougher with bigger turbos, but it may help you leave harder at the track and especially on the streets and thus produce better Elapsed Times. He can dial-up your mid and top end so your killer MPH [top-end charge] remains. Just an idea.
Nevertheless, congrats - great runs under a such crappy DA and no meth....9's is right there amigo.
Thanks,
E-Gear
Old Sep 29, 2016 | 11:50 AM
Thanks,
E-Gear
Hey Carlos. So I have a "Traction map" to try and also one for stage 3. In your honor it's called "Carlos/100 Traction" that I will dial in to the individual car. So much fun to experiment and hit challenged hard!
