By Design - John Bray 991TTS Motor Build
Thunder, I did rods and 12mm head studs, cams, inconel valves and CNC ported heads.
It's getting exciting. I know we gave you a teaser and then I kept your car LOL. Prototype axles are here and the Stage 2 Dodson Motorsport upgrade is at LAX! I'll be putting everything together next week but I'm going to fire her up for you before we drop the engine/trans again just to hold you over and I'll post a video tomorrow!
Ive run the stock diverter valves the the whole time with no issues, when we pulled the engine out I figured might as well put in some forge units.
If you need some let me know, I keep them in stock.
Tom I already purchased them from you, I got them awhile ago when I picked up your intercoolers I just never installed them.
The Camaro is running with the procharger and it really runs strong Ive got the outa the box tune in it now and its a tire fryer with t/c on or off. Ive still got to do headers, cat delete, plugs and 160 thermostat and custom tune, that will all happen in about two weeks which should be good for another 50ish whp. Oh ya I bought 17" Hoosiers for it also. Funny all that and it may run with a stock 991.1 on a good day from a roll
Cool. Looks like the event is pretty light (lower hp cars). You will probably get a lot more close races with the camaro. Looking at the list there isn't much signed up that can hang with a modded Turbo S from a dig.
I will be using this event to tune my car and better my trap speeds & see what kind of top speeds I can achieve in the 1/2 mile.
The Camaro will be fighting for traction, and yes it will have some good races Sunday there are only 70 or so cars should get in many runs.
Adam I have no doubt you will beat most of the cars out there, looks like the 1000hp gtr and 1000hp viper would be a good run.
I wish could go to this, but I'm going to be out of the country. I'd like to get real numbers for the .2.
I see one other 991.2 on the list idk who it is or if its modded I will find out what it runs, Plan B you can always drop the car off early and I will be more than happy to run it down the track for you!
