White Porsche 991 Turbo S Gets BBi Autosport Stage 2 Power Package
Attachment 1
To make this Porsche 991 Turbo S a faster car than it already is, we recently installed our BBi Autosport Stage 2 Power Package. The package includes of our Barcode Exhaust System, IPD Plenum & Y-Pipe, Cobb Tuning Access Port. Here are some detailed pictures of the build process and upgraded parts that we would like to share below.
BBi Autosport Stage 2 Power Package Includes:
Cobb Tuning Porsche 991 Turbo Accessport V3
Features
Power Gains: Stage 1 increases power throughout the low and mid-range with maximum gains of around 60 whp are seen between 3000-4000 RPM. Low-end torque is increased by over 100 ft./lbs! Stage 2 gains 120 ft./lbs down low and nearly 100 hp. at peak.
Simple Installation: Everything is included for the simple installation you can do in your driveway! Intuitive on-screen instructions identify your exact vehicle, saves stock vehicle data, and displays available OTS maps.
Change Maps: Store up to 100 maps from our OTS map database or from your favorite COBB tuner and quickly switch between them for any need.
Vehicle Upgrade Support: As you continue to modify your car, Accessport maps can be used to optimize performance upgrades. Changing the map can be done in less than 1 minute in your driveway.
In Car Mount: The Accessport can be mounted in the vehicle to allow you to monitor the performance data.
Data Logging: Record multiple data channels simultaneously for in-depth evaluation of engine performance. Stores up to 1 hour of continuous data.
Gauges: Use your Accessport as a gauge to monitor boost or any other live information, directly from the ECU.
Trouble Codes: Read engine trouble codes to diagnose issues. Clear them when resolved. Prevent expensive trips to the dealership.
Full Uninstall: Using the Uninstall option will completely remove our programming from the cars ECU. It is then able to be re-installed after a dealer visit or on another vehicle.
BBi Porsche 991 Turbo Barcode Exhaust
Produces more aggressive exhaust sound
Reduces restriction to increase horsepower, torque, and improve throttle response
304 stainless steel aerospace tubing
3" diameter piping throughout system
Meticulously TIG welded
Brushed stainless finish
Significant weight savings
HJS OBD2 compliant 200 cell catalytic converters
No CEL (Check Engine Light)
Direct bolt on replacement
Stylish design with laser etched BBi logo
Optional high temperature black ceramic coatings available
Handcrafted in the USA
For off-road use only
IPD Porsche 991 Turbo /S Plenum
IPD 991 Turbo /S High Flow Y Pipe
IPD 991 Turbo Plenum & Y-Pipe Features:
Increases horsepower, torque, and boost responsible optimizing air flow efficiency
Designed with 3D Modeling & Computational Fluid Dynamics software
Utilizes diversion splitter and dimpled interior surface eliminate turbulence and increase air flow
High quality cast aluminum construction
Direct fit OEM replacement
Made in the USA
We replaced the factory restrictive OEM plenum and y-pipe with the improved IPD system.
IPD Plenum & Throttle Body Installed Installed on Vehicle
OEM vs IPD Y-Pipe
IPD Plenum & Y-Pipe Package Mock Up & Dissected View
Installation of Exhaust and IPD Plenum & Y-Pipe Completed
Completed Project
- Jerry@BBiAutosport.com
Features
Made in the USA
OEM vs IPD Y-Pipe
Completed Project
BBiAutosport
Dec 5, 2017 04:42 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Jul 21, 2015 03:25 PM
PelicanParts.com
991 Vendor Classifieds
Jul 21, 2015 03:24 PM
