White Porsche 991 Turbo BBI Autosport Roll Bar Install
Old Dec 21, 2017 | 02:24 PM
BBiAutosport's Avatar
BBiAutosport is infamous around these parts
Attachment 1
Here is our BBi Autosport Porsche 991 Turbo with 991.2 GT3 Body Conversion that was unveiled at Targa Trophy 6th Annual Holiday Cruise & Food Drive. This build features Forgeline Motorsports Carbon Wheels, Michelin Tires, IPD Plenum/ COBB Tuning / BBi Exhaust Power Package, and BBi Roll Bar.
Roll Bar & Aero Installation
[size="5"]BBi Autosport Porsche 991 Turbo Bolt-In Roll Bar[/size]
[size="4"]Features[/size]
  • 1.625" x 0.095" 4130 chrome moly steel tubing utilized for excellent strength to weight ratio
  • TIG welded and utilizes "X" braces on both front and rear sections for superior strength and rigidity
  • Mounts to frame structure (utilizing factory bolts) to provide strongest mounting points and maximum protection
  • Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
  • Designed to work with stock seats or any aftermarket seats on the market
  • Allows full seat travel to accommodate taller drivers
  • Can be used with stock seat belts or 6 point harnesses for track use
  • Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
  • OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
  • Finished in satin black powder coat. Other colors available Bolt-in installation requires no drilling and minimal carpet trimming
  • Made in the USA
Inside
Exterior Completed Project
- Jerry@BBiAutosport.com
