991 Vendor Classifieds Vendors post your classifieds here
ModBargains
Old Jan 7, 2014 | 11:17 AM
ModBargains's Avatar
ModBargains is infamous around these parts
ModBargains
ModBargains.com is happy to continue to offer the 6speedonline community with the top of the line wheels from Forgestar:
The Forgestar F14. The Forgestar CF10. The Forgestar CF5.
This brand new lineup utilizes a combination of the best methods of forging and casting methods both in the same wheel. This is called Flow Form Casting, and is used by companies such as BBS and Enkei. These wheels are made to order and can be made to fit your Porsche with a large range of offsets.
Rotary Forged Flow Form Casting is a production procedure that turns the wheel (or rim section) over a special mandrel and three hydraulic rollers using tremendous pressure. The pressure and turning then force the rim area to form against the mandrel, creating the shape and width of the rim. During Flow Forming, the rim actually "flows" down to create the full rim width. During Flow Forming, pressure applied to the cast rim actually changes its mechanical properties, so its strength and impact values become similar to those of a forged rim. That translates to up to 15% less weight when compared to a standard cast wheel.
Oh yeah one more thing CUSTOM sizing and offsets guys! Forgestar wheels are available in a 18", 19", and 20" allowing you to decide exactly what diameter and width you want to run on your vehicle, rather being forced to run a set staggered size with cast wheels. Forgestar wheels can be made in virtually any offset, whereas standard cast wheels come in a set offset. This allows you to dial in exactly how you want your wheels to sit. Having custom offsets allows for fitment of wider wheels in stock suspension and lowered vehicles. Forgestar wheels are designed specifically for your car and it's suspension setup, where cast wheels are designed for everyone and typically do not take in to account lowered suspension setups.
Approximate F14 Weights:
18x8.5 ET48 - 17.6 Lbs.
18x9.5 ET48 - 18.4 Lbs.
18x10 ET42 - 18.2 Lbs.
18x12 ET68 - 20.0 Lbs.
19x8.5 Approx weight 22.5 lbs !!
19x9 Approx weight 24.1 lbs !!
19x10 Approx weight 24.7 lbs !!
Available F14 Offsets and Sizes:
18x8.5 offsets from +26 to +50 SC
18x9.0 offsets from +20 to +55 SC
18x9.5 offsets from +26 to +60 SC
18x10.0 offsets from +16 to +42 DC
18x11.0 offsets from +23 to +55 DC
18x12.0 offsets from +36 to +68 DC
19x8.5 offsets from +26 to +48 SC
19x9.0 offsets from +20 to +50 SC
19x9.5 offsets from +4 to +44 DC
19x10 offsets from +20 to +45 DC
19x11 offsets from +23 to +55 DC
19x12 offsets from +36 to +68 DC
19x9.5 offsets from -25 to +23 SDC - NEW
19x10 offsets from -19 to +30 SDC - NEW
19x11 offsets from -6 to +43 SDC - NEW
19x12 offsets from +6 to +55 SDC - NEW
20×8.5 offsets from +26 to +50 SC
20×9.0 offsets from +18 to +56 SC
20×9.5 offsets from +7 to +43 DC
20×10 offsets from +31 to +69 SC
20×10.5 offsets from +20 to +55 DC
20×11 offsets from +48 to +81 SC
20×12 offsets from +39 to +75 DC
These Forgestar Wheels are available in almost ANY finish. All finishes are in a high quality, incredibly durable Powder Coat. Some of the most popular are: Matte Black, Gloss Black, Gunmetal, Textured Gunmetal, Textured Black.
Forgestar F14 on Boxter S
F:19x8.5 ET48 R:19x11 ET33 Gunmetal
Forgestar CF5 on Boxter Spyder (Widebody)
F:18x10 R 18x12 Textured Matte Black
Forgestar CF10 on 996 Turbo
F:19x8.5 R:19x11 Gunmetal
Forgestar F14 on 997 Carrera S
F:19x8.5 R:19x11 - Matte Black
NEED HELP OR HAVE ANY FITMENT QUESTIONS PLEASE CALL ME: ELLIOTT 714-582-3330 x8009 OR EMAIL ME AT ELLIOTT@MODBARGAINS.COM
Old Jan 7, 2014 | 11:55 AM
thigos's Avatar
thigos is infamous around these parts
email sent.
Old Jan 7, 2014 | 05:25 PM
Originally Posted by thigos
email sent.
Email responded! Thanks for the opportunity to help out!
ModBargains
Lotus Vendor Classifieds
Oct 13, 2015 03:42 PM
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
ModBargains
Sep 10, 2015 12:00 PM
