Personal settings (besides the seat)
Old Dec 16, 2012 | 06:40 PM
ArashApollo's Avatar
ArashApollo is infamous around these partsArashApollo is infamous around these parts
Hey guys. So I'm having some confusion with setting the seat memory (1,2,3). I have realized that with one key, you can change the seat position/mirrors/steering wheel, but all the personal and vehicle settings (the car menu, light options, comfort entry, and so on) can only be stored on number 3 (which saves things onto the key). If you change those personal and vehicle settings, and press -set, 1-, and then some other driver comes in and presses -2-, all your personal and vehicle settings will be lost. The only way to save those other settings is by pressing -set, 3-, which will also set the same personal settings for memory 1 and 2.
Lets say that the spouse likes to display fuel range, time and the likes on the PCM display, have the map 3D in the gauge cluster, and have ambient light set to 100%. Lets also say that you like different settings for all those things, you will need two different keys, and store whatever settings you want by pressing -set, 3- with YOUR key in the car.
If I'm wrong, please correct me. I just wanted to share this as I finally sat down and learned the thing.
Old Dec 17, 2012 | 05:45 PM
ale70's Avatar
ale70 is a name known to allale70 is a name known to allale70 is a name known to allale70 is a name known to allale70 is a name known to allale70 is a name known to all
I think i am half lost on this subject.....sorry....cant really figure out what is what, yet....
Old Dec 17, 2012 | 11:37 PM
dhill911's Avatar
dhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond repute
Set 3 programs the key only. You have 2 keys that can be programmed independently.
Old Dec 18, 2012 | 06:53 AM
ale70's Avatar
So if i press 3 with my key it gets to my settings and if i press 3 with the other key it goes to the other settings?
and 1 and 2 are for people without a key, like a son?
Old Dec 18, 2012 | 07:19 AM
gjnockie's Avatar
gjnockie is infamous around these parts
Does anyone know if you can wipe out the settings completely so there are no settings saved to the key? Sort of a factory reset so to speak.
Old Dec 18, 2012 | 08:27 AM
dhill911's Avatar
Yes, but you must have "Automatic Storage Of Settings On Vehicle Keys When Locking" deactivated in the Multi-Function Display. Here is how you check/change this in the Multi-Function Display: 1) Main Menu "Vehicle" 2) select "Settings" 3) select " Locking" 4) select "Auto Memory" 5) select "Deactivate"
Old Dec 18, 2012 | 08:50 AM
ale70's Avatar
THIS is the information I was looking for! Thank you!!
Jul 29, 2019 11:13 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
riozilla
Aug 21, 2015 11:34 PM
pwdrhound
Aug 20, 2015 05:54 AM
