Porsche dual-mode battery charger question?
Old Feb 9, 2013 | 12:18 PM
991s's Avatar
991s is infamous around these parts
I checked in the manual and it says the two power outlets only have power for 30 mins after the ignition is switched off. So, I'm guessing this means charging via either of these won't work.
FYI - these two outputs have a max load of 20 amps.
Old Feb 9, 2013 | 12:28 PM
PorscheCrazy's Avatar
Looks like you will need to do a direct hook-up to the battery then.
Old Feb 9, 2013 | 12:33 PM
991s's Avatar
I guess so.
Now I wish I had the smoking pkg!
Old Feb 9, 2013 | 01:07 PM
Originally Posted by 991s
I guess so.
Yep, that is exactly why I got it. I don't smoke but knew I wanted the extra plug in, just in case . . .
Old Feb 9, 2013 | 02:12 PM
chuckbdc's Avatar
chuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud of
I am going to have to look in the manual and check with the dealer. I have plugged in the Porsche (CTEC) charger several times and had it go from indicating "charging" to indicating "charged" overnight. I have not tried charging it for more than overnight though, so maybe it was all topped off in 30 minutes!
Old Feb 9, 2013 | 03:38 PM
montreal red's Avatar
montreal red is infamous around these parts
just buy the non porsche charger and do a direct hook up. no big deal. you can still close the trunk even with the wires attached to the battery the cables are small enough that they dont get pinched much.
Old Feb 9, 2013 | 04:13 PM
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
The CTEC is a tender, not a charger, so it's not supposed to full charge the battery, but let the battery drain and then charge as it would with normal cycles from driving it with the alternator.
Old Feb 9, 2013 | 06:43 PM
dhill911's Avatar
dhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond reputedhill911 has a reputation beyond repute
Originally Posted by dhill911
I use a battery tender and hook it up at the battery under the hood. I like it better because I don't have to leave a window cracked. Just personal preference. Same result.
In your case, don't you have to leave the hood up or open a crack? Or do you close the hood on the wire?
Yes, you are correct. I leave the hood down and latched, but not fully closed.
Old Feb 10, 2013 | 11:20 AM
Snowczar's Avatar
Snowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to behold
I have the Porsche version/named CTek and plug into the lighter socket on my 996 TT Cab. I specifically ordered the smokers package to get that plug. I have a 991S Cab coming around the end of the month and already bought another one for that car (I'm keeping the TT). Both cars are "Garage Queens/Toys". I find I can close the passenger door with the cord over the window with no issue. Or I just lower the rear window 1/4".
John in Vancouver
Old Feb 10, 2013 | 05:03 PM
carcam's Avatar
carcam is infamous around these parts
Just remember that it is plugged in before you take off driving. I used to run it in from the passenger side, now I do the driver side. Don't ask me how I figured this out...
Old Feb 11, 2013 | 09:23 AM
Woodster's Avatar
Woodster is a jewel in the roughWoodster is a jewel in the roughWoodster is a jewel in the rough
Good advice, that sounds like something I would do.
Old Feb 11, 2013 | 09:27 AM
Snowczar's Avatar
I drape the power cord over and around the steering wheel so I don't back out and try and drag the whole garage with me.
John in Vancouver
COBB Tuning
Jan 1, 2025 09:02 AM
pwdrhound
Sep 16, 2021 02:27 PM
joseph_number1
Jul 19, 2018 05:45 PM
DSCOFF
Aug 23, 2015 01:22 PM
Aug 21, 2015 09:56 AM
