Oil temp and MPG question
Old Nov 11, 2013 | 02:47 PM
certified_prime's Avatar
certified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of lightcertified_prime is a glorious beacon of light
So, when Sport is engaged, my Oil temp drops from 225 degrees down to 200 degrees. MPG also decreases significantly.
Is the change in MPG just due to the extra parasitic drag on the engine from the oil cooler, or does the slightly hotter temperature of the oil also play into engine and fuel ignition efficiency?
Regardless, the efficiency of this engine is pretty amazing. I get 10-15 MPG when driving aggressively through the twisties, but I manage a very consistent 27 MPG when cruising on the highway. The former is to be expected from a sports car...the latter makes me a happy commuter when travelling for business and really makes the car a great daily driver.
Old Nov 11, 2013 | 03:43 PM
chuckbdc's Avatar
chuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud ofchuckbdc has much to be proud of
I have have PDK, and the Sport setting sensitivity to revs means it shifts into lower gears more often. I suppose that means less mileage, but its good enough that I gave up caring some time ago.
Old Nov 11, 2013 | 05:54 PM
I have a manual trans. And it's not just a more aggressive shifting point. I average a healthy 27 MPG in normal mode with highway driving consistently while in 6th gear. With Sport engaged, it is closer to 22-23 MPG I believe.
I am mostly just curious if that is all due to the parasitic drag from running the oil cooler. If so, no wonder why they went with electric steering to get rid of that pulley as well.
Old Nov 12, 2013 | 06:57 AM
kosmo69's Avatar
kosmo69 is just really nicekosmo69 is just really nicekosmo69 is just really nicekosmo69 is just really nice
My tech would agree w/ you.
however thats a big decrease in your MPG. Strange.
Old Nov 12, 2013 | 07:15 AM
chuckbdc's Avatar
I think the oil flows through the oil cooler all the time, and it gets adjusted for more flow in Sport setting. It is an oil to water radiator and given that it is well lubricated :-) I doubt that the difference creates enough "drag" to affect MPG. More likely it is done to improve warm up time and meet specific demands of the emisions regulations.
Old Nov 12, 2013 | 09:53 AM
lunarx's Avatar
lunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to behold
Thats interesting on the highway MPG.
How are you measuting MPG?
I am fairly certian the PCM is not accurate.
Old Nov 12, 2013 | 09:55 AM
HotHonda's Avatar
HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !
PCM highway (7th gear mostly) at speed limit getting 27-28 MPG. 8K ODO
Jul 29, 2019 11:13 AM
RallyBird
Oct 7, 2015 01:20 PM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
The Oss
Aug 24, 2015 08:19 PM
