Side skirt repair or replace
Old Nov 23, 2013 | 09:58 AM
Dilligaf's Avatar
Dilligaf is a name known to allDilligaf is a name known to allDilligaf is a name known to allDilligaf is a name known to allDilligaf is a name known to allDilligaf is a name known to all
One of my side skirts recently got hit with a rock and left a good gouge towards the bottom right near the back tire, it was very obvious since it was a white mark on a black car. Has anyone found a repair for this or a good spot to buy replacement skirts without a trip to the dealer? I have done a couple of searches but came up empty.
Old Nov 23, 2013 | 11:09 AM
lunarx's Avatar
lunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to behold
Does the 991 C2S even have replaceable side skirts?
The C4S has skirts but I thought the C2S had a non-skirt that was just part of the body.
Is your damage on the rough texture part or higher up on the smooth part?
I just noticed a chip on mine , just above the texture, and figure I will touch it up and finally get PPF on my rockers, as I intended to do before it got chipped.
That's what I get for waiting.
Old Nov 23, 2013 | 12:08 PM
Dilligaf's Avatar
My damage is on the lower rough surface. I am not sure if it is a part designed for replacement, but the lowest section looks like it should be replaceable.
Old Nov 23, 2013 | 01:01 PM
lunarx's Avatar
That rough surface is easy to mask off and paint.
Unless it is replaceable
If there is a nice aftermarket rocker, it's worth considering to have something replaceable.
Have you looked into that?
Lowtush
Jan 25, 2022 10:48 AM
gulf gt
Aug 27, 2015 10:27 AM
manishdutta
Aug 21, 2015 09:49 AM
Jeff1smith
Aug 19, 2015 09:41 PM
