Brake compatibility question...
Old Jan 6, 2014 | 04:37 PM
socalsteve's Avatar
socalsteve is a name known to allsocalsteve is a name known to allsocalsteve is a name known to allsocalsteve is a name known to allsocalsteve is a name known to allsocalsteve is a name known to all
Hi all,
A long shot, but worth a try...
Are the OEM pads & rotors of a 997.2 base model compatible with the pads & rotors of a 991 base model?
I have a set off my 2012 997.2 and am thinking of buying a 991. Just curious if I can keep them and use them or have to sell them.
As always, thank you all in advance!
Steve
Old Jan 6, 2014 | 05:26 PM
BradB's Avatar
BradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to allBradB is a name known to all
No. Pads and rotors are 991 specific. To date you can get OEM or Pagid 29 pads.
Old Jan 6, 2014 | 05:36 PM
socalsteve's Avatar
Thank you!
Guess Ill have to sell them locally as they weigh a bit and shipping would be prohibitive.
Steve
Old Jan 6, 2014 | 06:44 PM
mtony's Avatar
mtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond repute
On a similar note, are the front pads of the Carrera S the same as the base Carrera? I see that Carbotech has a ceramic brake pad that fits the Carrera. Just wondering if they fit the S also.
Old Jan 6, 2014 | 11:50 PM
lunarx's Avatar
lunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to beholdlunarx is a splendid one to behold
Originally Posted by socalsteve
Hi all,
Steve
The 991 Base uses 997 series Front brake parts.
Front Pad: 997 351 938 11
Front Rotor (L): 997 351 401 01
Front Rotor (R): 997 351 402 01
The 991 Base uses 991 series rear brake parts.
Rear Pad: 991 352 939 02
Rear Rotor (L): 991 352 401 00
Rear Rotor (R): 991 352 402 00
The 997 Base uses these Front brake parts.
Front Pad: 997 351 938 03
Front Rotor (L): 997 351 401 00
Front Rotor (R): 997 351 402 00
Front 991 Base & Front 997.2 Base look to be the same.
Only those last 2 digits are off which usually just means an updated part.
You might be in luck
Old Jan 6, 2014 | 11:54 PM
lunarx's Avatar
If you are talking 991 Base to 991S they are not the same.
991 Base Front Pad: 997 351 938 11
991 S Front Pad: 991 351 949 02
Remember the S has the larger monoblock calipers.
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
