High Oil Pressure Concerns After Mods
Old Feb 23, 2017 | 05:47 PM
cartertims's Avatar
cartertims is infamous around these parts
Exclamation High Oil Pressure Concerns After Mods
Hi all,
I have a 991 Turbo that I just installed a GMG exhaust and applied a Stage 2 Cobb Accessport tune. I just test drove it and under heavy throttle it continues to get almost all the way up to the oil pressure read line continually hitting 58psi. Is that bad? Is that normal? Should I be concerned about blowing a gasket somewhere potentially?
I like to take this car to DE events. I am concerned if i run it like that for 3hrs a day it could be very bad for my motor. Valid?
Thanks in advance for your input and opinions.
CT
Old Feb 24, 2017 | 09:34 AM
grover432's Avatar
grover432 is infamous around these parts
Is it still under warranty?
Old Feb 24, 2017 | 10:13 AM
cartertims's Avatar
Yes but only till Dec 2017. I am going to extend two years but cost like $4k
Old Feb 24, 2017 | 10:44 AM
991C4s's Avatar
991C4s is a splendid one to behold991C4s is a splendid one to behold991C4s is a splendid one to behold991C4s is a splendid one to behold991C4s is a splendid one to behold991C4s is a splendid one to behold991C4s is a splendid one to behold
What was the oil temp? Colder oil temp higher oil pressure.
Old Feb 24, 2017 | 08:31 PM
grover432's Avatar
Then go ask your dealer if the high oil pressure will blow your engine before it does or you will be paying for a new motor yourself
Old Feb 25, 2017 | 09:44 AM
GS997S's Avatar
GS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond repute
Probably not any longer after the mods.
