991 Rear camera retro fitting
Old Feb 8, 2020 | 03:53 AM
zenman63's Avatar
zenman63 is infamous around these parts
Old Feb 8, 2020 | 09:02 AM
zenman63's Avatar
Old Feb 8, 2020 | 09:09 AM
zenman63's Avatar
All now installed mission to get the wires in the factory positions, runs behind cluster etc so all that has to come out, I went for a dedicated live, easy enough to get a new pin in the back of the fuse box.
New ground on the body next to fuse box.
No errors on pcm so now to Porsche to code and calibrate,
Old Feb 8, 2020 | 11:10 AM
zenman63's Avatar
Old Feb 8, 2020 | 11:14 AM
zenman63's Avatar
Guys just put the fuse in and bingo, comes on fine, still needs coding to b able to change the image and the pcm 4.0 does not have any settings for it.
Good result for what was said to be impossible, everyone I have spoken to said no way can it be done.
Old Feb 19, 2023 | 06:45 AM
bmwamac's Avatar
bmwamac is infamous around these parts
Originally Posted by zenman63
As above cannot fine anyone that has done this so having a go on mine.
Used camera on the way from a crashed car, cheap enough, new harness ordered, it plugs into the parking sensor harness, my cars module supports it according to Porsche.
New mounts ordered from Porsche, so until the bumpers comes off not sure the wire the other side of the plug is there.
Pictures to follow.
have you any pictures I’m on the same journey and mimic'd yours just about to install. Which side of the car do the cables travel
Old Feb 20, 2023 | 10:38 AM
zenman63's Avatar
There are no wires in the car, it needs wiring back to head unit.
Old Feb 20, 2023 | 10:40 AM
zenman63's Avatar
the wires are drivers side Uk car.
I do have pictures yes, later I will put them up.
Old Feb 20, 2023 | 12:07 PM
zenman63's Avatar
Old Feb 20, 2023 | 12:08 PM
zenman63's Avatar
Old Feb 20, 2023 | 12:10 PM
zenman63's Avatar
Old Feb 20, 2023 | 10:47 PM
bmwamac's Avatar
Much appreciated, have all three video cables purchased from OEM plus rear wiring harness, the 991.1 GT3RS doesn’t have rear sensors so parted the rear harness of the sensors and that just left the 4 pin camera connector with bracket shown in your photos. Have the same setup with camera and bracket as shown in your photos too. Will post all part number’s shortly but still missing the 2 pin connector X251 for positive and ground I know the positive goes to fuse B3 (5A) drivers side fuse box (for UK car) and ground goes to GP21 so just need to find them now.
Old Feb 21, 2023 | 12:48 AM
zenman63's Avatar
There is also body canbus in the harness.
Old Feb 21, 2023 | 11:00 AM
bmwamac's Avatar
Camera
Harness from camera to RHS rear light area
Rear harness from camera to RHS rear light area
From PMC3.1 to drivers side front area
Showing CanBus, positive and ground
Old Mar 1, 2023 | 10:19 AM
Caridad_Peters's Avatar
Caridad_Peters is infamous around these parts
Thank you for sharing!
