993 Turbo This community is about the last air cooled twin turbocharged Porsche 911. Model year 1996 - 1997. Also inclusive in this forum is talk on the final 182 Porsche 911 Turbos built in 1997 known as the Turbo S.
Ecu flash
Old Jun 8, 2010 | 12:26 PM
993turboTim's Avatar
993turboTim is infamous around these parts
Ecu flash
Any way to flash a 96 ECU??
Old Jul 14, 2010 | 12:33 PM
CaptainCalf's Avatar
CaptainCalf is infamous around these parts
I've got a sneaky suspicion that there's no easy answer since nobody has chimed in...
I would like to know the solution too, so I suggest you contact Steve W @ Rennsport...
Old Jul 15, 2010 | 11:12 PM
TheVenom's Avatar
TheVenom is infamous around these parts
my friend says cant be flash. chip needs to be removed and programmed.
Old Jul 17, 2010 | 08:43 AM
Sonny's Avatar
Sonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud of
Best is to change to a later style ecu (97'), cheers.
Old Apr 10, 2011 | 06:11 PM
jayster's Avatar
jayster is infamous around these parts
Softronic.us
Old Apr 11, 2011 | 08:03 AM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
You can definitely add performance software to a '96, but the process to do so is a little different then on new OBDII cars.
On a '96 it would require removing the ECU and physically adding a performance "chip". GIAC has some options available.
Oct 6, 2015 06:13 PM
Oct 2, 2015 02:23 PM
