993 Turbo This community is about the last air cooled twin turbocharged Porsche 911. Model year 1996 - 1997. Also inclusive in this forum is talk on the final 182 Porsche 911 Turbos built in 1997 known as the Turbo S.
993 tt c.e.l. !?!?!?!?!?!
Old Dec 9, 2010 | 08:23 PM
carmstrongLS1's Avatar
carmstrongLS1 is a glorious beacon of lightcarmstrongLS1 is a glorious beacon of lightcarmstrongLS1 is a glorious beacon of lightcarmstrongLS1 is a glorious beacon of lightcarmstrongLS1 is a glorious beacon of light
Unhappy 993 tt c.e.l. !?!?!?!?!?!
Just had a boatload of work done... Car ran with a few "pops" in the exhaust note here and there. Then I started it today. Drove about a mile at about 30 mph. Came to a stop to take a right turn. When all was clear I gave it a little gas and at about 3000 rpm in first gear the car fell flat on its face, the lights and gauges dimmed a bit, The exhaust popped loud twice and the gosh damn Check engine light came on and stayed on. I immediately took the car back to my storage unit, Let it idle for a bit and then turned it off for about a minute or so. Turned the engine back on and the light was still there. Any ideas why this might happen guys? The work done is below:
Labor Porsche Work Performed - R/R engine assembly, reseal right timing chain housing, front crank seal & all related components. Replaced broken alternator fan shroud, air filter & spark plugs. Cleaned & road tested. Reinspected, no leaks found.
Parts:
Chain Case Gasket, Timing Cover Gasket, Chain Tensioner Gasket, Intermed Shaft O-Ring, Oil Thermostat O-Ring, Crankshaft Seal
Main Bearing O-Ring, Camshaft O-Ring, Cam Retainer Gasket, Spark Plug FR6LDC, Alternator Shroud, Air Filter Element,
Oil 0w-40 Synthetic
I can't stand spending a boatload of money on something that is a dead horse.
Also, Does anyone recommend any specific OBD scan tools?
HELP Please!?!?!?!?!
Old Dec 9, 2010 | 10:46 PM
dfwerdoc's Avatar
dfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud of
chris who did the work for you? give them a call and let them know ....
Old Dec 10, 2010 | 01:09 AM
VID997's Avatar
VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !
Alternator.
We are on second one in 12+years... oddly our’s just went this morning. Something is causing a draw..door sensors (i.e. lighting switches, DME, or ignition tumblers...). We have been trying to track the problem down. Their has got to be a short somewhere (in both our vehicles). These cars are not worth giving up on....they are just way too curvy to let slip out of our fingers.
Old Dec 11, 2010 | 04:32 AM
Cel
So i scanned the car with a innovate multi scan too (Badass BTW) Came out with a P0301 cylinder 1 misfire
Freeze frame
2nd gear
2800 rpm
50 mph
Anyone had good results with any particular carbon cleanups? I want to do one the right way with no BS chemicals in my cars veins. This thing is my baby. I reset the light and drove it another 50-60 miles today. Flawless operation... Just ask the C6 vette driver with the license plate "BADNUF" Seriously though... Any suggestions?
nal991
Apr 5, 2022 08:58 PM
WheelB
Wheels/Tires
Sep 14, 2016 08:59 PM
Martinator
911
Sep 30, 2015 10:31 AM
PelicanParts.com
993 Turbo Vendor Classifieds
Sep 21, 2015 03:12 PM
CSmyth
Sep 16, 2015 09:54 AM
