:: ECS Tuning :: Exact Fit Stainless Steel Brake Lines | Starting At $64.95!
If you spend time and money renewing your brake hardware and linings, you ought to consider upgrading to ECS Tuning Exact-Fit brake hoses. These premium brake hoses are stronger, more durable, and better protected than the originals.
They are shielded in stainless steel mesh reinforcement, and coated with bright red vinyl for added protection. Available by the axle for front or rear, or as a complete vehicle set.
Click Here for more information
Even when new, factory style fabric mesh lined rubber hoses are prone to expansion under the pressure of hard braking, whether it be highway panic stops or threshold braking at the track. This expansion is even more prominent in aged and weathered rubber hoses. Our lines are reinforced with braided stainless steel mesh, affording superior expansion resistance. This resistance to expansion creates a firmer pedal, and a more direct pedal feel. Our signature red polymer coating provides additional protection from the elements and abrasion common with the constant movement of suspension and braking systems.
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
oddjob142
Aug 19, 2015 12:27 PM
