Brembo Brake Kits From Exotica Motorsports!
Subscribe993 Front1995-1998 355x32 2-Piece$3,295.00
993 Front1995-1998 355x32 2-Piece$3,495.00
993 Front1995-1998 380x32 2-Piece$3,595.00
996 C2 Front1999-2004 355x32 2-Piece$3,295.00
996 C2 Front1999-2004 355x32 2-Piece$3,495.00
996 C2 Front1999-2004 380x32 2-Piece$3,595.00
996 C2 Front1999-2004 380x32 2-Piece$3,995.00
996 C2 Rear1999-2004 345x28 2-Piece$2,995.00
996 C2 Rear1999-2004 380x28 2-Piece $3,195.00
996 C4 Front1999-2004 355x32 2-Piece$3,295.00
996 C4 Front1999-2004 355x32 2-Piece$3,495.00
996 C4 Front1999-2004 380x32 2-Piece$3,595.00
996 C4 Front1999-2004 380x32 2-Piece $3,995.00
996 C4 Rear 345x28 2-Piece$2,995.00
996 C4 Rear 380x28 2-Piece $3,195.00
996 C4S, Turbo Front 355x32 2-Piece$3,495.00
996 C4S, Turbo Front 380x32 2-Piece$3,595.00
996 C4S, Turbo Front 380x32 2-Piece$3,995.00
996 C4S, Turbo Rear 345x28 2-Piece$2,995.00
996 C4S, Turbo Rear 380x28 2-Piece $3,195.00
997 C2 Front2005> 355x32 2-Piece$3,295.00
997 C2 Front2005> 355x32 2-Piece$3,495.00
997 C2 Front2005> 380x32 2-Piece$3,595.00
997 C2 Front2005> 380x32 2-Piece$3,995.00
997 C2 Rear2005> 345x28 2-Piece$2,995.00
997 C2 Rear2005> 380x28 2-Piece $3,195.00
997 C2S Front2005> 355x32 2-Piece$3,495.00
997 C2S Front2005> 380x32 2-Piece$3,595.00
997 C2S Front2005> 380x32 2-Piece$3,995.00
997 C2S Rear2005> 345x28 2-Piece$2,995.00
997 C2S Rear2005> 380x28 2-Piece $3,195.00
997 C4 Front2006> 355x32 2-Piece$3,295.00
997 C4 Front2006> 355x32 2-Piece$3,495.00
997 C4 Front2006> 380x32 2-Piece$3,595.00
997 C4 Front2006> 380x32 2-Piece$3,995.00
997 C4 Rear2006> 345x28 2-Piece$2,995.00
997 C4 Rear2006> 380x28 2-Piece $3,195.00
997 C4S Front2006> 355x32 2-Piece$3,495.00
997 C4S Front2006> 380x32 2-Piece$3,595.00
997 C4S Front2006> 380x32 2-Piece $3,995.00
997 C4S Rear2006> 345x28 2-Piece$2,995.00
997 C4S Rear2006> 380x28 2-Piece $3,195.00
997 GT3 Front (Excluding PCCB)2006> 380x32 2-Piece$3,995.00
997 GT3 Rear (Excluding PCCB)2006> 380x28 2-Piece $3,195.00
997 Turbo Front (Excluding PCCB)2006> 380x32 2-Piece$3,995.00
997 Turbo Rear (Exlcluding PCCB)2006> 380x28 2-Piece $3,195.00
Cayenne Front2003> 380x34 2-Piece$4,295.00
Cayenne Front2003> 405x34 2-Piece$4,295.00
Cayenne Rear2003> 380x28 2-Piece $3,195.00
Cayenne Rear (1-Piece)2003> 358x28 1-Piece$2,395.00
Porsche Monobloc Kits (Black Calipers Standard)
911 S, SC, Carrera Front1974-1989 282x24 1-Piece $1,595.00
911 S, SC, Carrera Front1974-1989 322x32 2-Piece$1,995.00
911 S, SC, Carrera Rear1974-1989 322x28 1-Piece $1,895.00
911 / 930 Turbo Front1975-1979 322x32 2-Piece$1,995.00
911 / 930 Turbo Front1980-1989 322x32 2-Piece $1,995.00
911 / 930 Turbo Rear1978-1989 322x28 1-Piece $1,895.00
Porsche Lightweight Kits
911S Front1966-1973 313x28 2-Piece$2,595.00
911S Rear1966-1973 305x28 1-Piece $1,895.00
911S Rear1966-1973 313x28 2-Piece$2,595.00
911 S, SC, Carrera Front 313x28 2-Piece$2,595.00
911 S, SC, Carrera Rear 305x28 1-Piece $1,895.00
911 S, SC, Carrera Rear 313x28 2-Piece$2,595.00
Porsche Big Red Kits
911 C2 / C4 Front 322x32 2-Piece $2,195.00
911 C2 / C4 Rear 300x24 1-Piece $1,995.00
993 C2 / C4 Front 322x32 2-Piece $1,995.00
993 C2 / C4 Rear 322x32 2-Piece $1,795.00
944 S/2 Non-M030 (w/o Sport Suspension) 322x32 2-Piece $2,195.00
944 Turbo 322x32 2-Piece $2,195.00
968 Non-M030 (w/o Sport Suspension) 2-Piece $2,195.00
944 Turbo 322x32 2-Piece $1,995.00
944 S/2 M030 (w/ Sport Suspension) 322x32 2-Piece $1,995.00
968 M030 (w/ Sport Suspension) 322x32 2-Piece $1,995.00
- Requires minor modification to the OEM steering knuckle
- Requires minor modification to the OEM steering knuckle and use of included custom hubs
- 1995 E36 M3 models require minor modification to the lower control arm outboard of the ball joint
- This system consists only of 2-piece disc assemblies which directly replace the OEM discs
- Requires significant modification to the OEM knuckle
- This system eliminates the parking brake function if not used in conjunction with parking brake kit
- This system is to be used ONLY with OEM rear brakes, not to be used with the rear upgrade kit
- Special order only
i will keep you posted on a brake kit soon...
Quote:
Good! I look forward to working with you.Originally Posted by porschenaround
