Erratic oil pressure ?
Old Oct 5, 2007 | 03:21 PM
timf's Avatar
timf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud of
For the past few years since I had a new engine installed under warranty at about 10,000 miles the oil pressure gauge has flickered around by about 1 to 2 markings - even at steady rpm.
Today it was doing it again but this time on the dash board the oil can warning light came on.
I'm thinking either my oil pressure dropped to zero or it was just a bigger glitch ?
Either way a little worrying. I checked the oil level and its fine, the engine sounds the same as ever at idle, noisy :-)
Anyone else had this issue -if so how was it fixed ?
I'm thinking it might be a loose connection on the oil pressure sensor ?
Old Oct 5, 2007 | 05:56 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
Tim,
I had an erratic oil pressure reading where the gauge would bounce around and drop to zero. When it dropped to zero, the light would go on and when the reading popped back up and the light would go out...it was the sender, which I learned is a common problem. I agree - when the light comes on, it is concerning.
Old Oct 5, 2007 | 06:03 PM
unvmy996's Avatar
if i may ask , what happen and you had ur motor replaced under warranty?
jpik2003
Sep 10, 2015 05:18 PM
ECS Tuning - VW
Sep 8, 2015 01:34 PM
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
ECS Tuning - VW
Sep 2, 2015 12:58 PM
