996TT Tech Specs
996TT Tech Specs
Hi,
I would like to know the following tech specs of the 996TT:
1- Injectors size
2- Fuel pressure
3- Fuel pump flow rate
4- What crank sensor Type (Hall Effect or Magnetic)
Any input will be appreciate it
Regards,
Husam.
1- Injectors size
2- Fuel pressure
Regards,
Husam.
2- Strong
3- Fast
4- Yes
Not sure where in these downloads you will find that info but I'm sure it's in there somewhere. Check all 3 pages.
http://www.esnips.com/web/rmrmd1956
Slant911,
I cant thank you enough man. these info is priceless to me i really appreciate it.
Husam.
Hi Husam,
Good to see you gaining interest in Porsche cars.
The 996TT injectors flow 44lbs and I htink they are rated at 3.0 Bar, so with a variable FPR at 3.8 Bar they should be seeing another 12.5% more, at 5Bar, another 15% on top of it, so they are good for about 680 BHP at the crank at that rating.
If you are going for high HP, I would advise you to change fuel pump anyway, use the Bosch 044. Looking forward to meet up again , on the track or elsewhere, regards to your brother.
Cheers
Cheers
The common injector upgrade is Seimans 60lb injectors, which obviously requires DME reprogramming.
Fuel lines also need to be upgraded to larger diameter...I am not sure what people are using though but I think it is 10AN. If you find out, let me know.
Hi Husam,
Cheers
Cheers
I thank you for the information it is really helpful. in fact there is a reason behind my interest and i guess you will know soon
. are the Bosch044 a direct replacement on the 996TT or do i have to modify it?By the way,are you in town?
Regards,
Husam.
Knowing you, it can only be wild!
I know you like it, but don't go Motec on these! You need the knock sensors.I am in Dubai now, you should join some of our track days and sprints.
BTW I am interested in a Skyline like yours for the track (endurance), let me know if you know of any please.
Edit: The 044 is a direct replacement, very little work tobe done.
Feelgood MD
Mar 24, 2016 09:35 AM
PelicanParts.com
Sep 11, 2015 02:41 PM
PelicanParts.com
996 Vendor Classifieds
Sep 11, 2015 02:40 PM
PelicanParts.com
996 Turbo Vendor Classifieds
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Sep 11, 2015 02:38 PM
