which Odyssey 925 battery for the 996tt?
which Odyssey 925 battery for the 996tt? there are several variants and i'm trying to figure out which one. advice please...
also as for battery mounts i found two options:
1. http://www.odysseybatteries.com/fullsize/hd925sm.htm
or
2. http://www.rennline.com/prodinfo.asp?number=EL30%2E35
which is the better one - or easier to install....
thanks!
boris
or
thanks!
boris
I just purchased the PC680T $125.000 with the mounting bracket. This Odyssey battery does not require a charger if you start the car at least once every two weeks. I spoke with Tony (951-736-3530) at West Coast battery. He is in Corona, Ca and kenw exactly which battery and mounting hardware I needed for my 996TTS. The battery specks are posted below.
PC 680T Specs:
Aluminum hold down box for the PC680 and the FAA approved small aircraft battery. Can be used with or without automotive terminals.
Also available with a textured matte black finish
PC 680T Specs:
- 680 cranking amps for 5 seconds
- 595 cranking amps for 10 seconds
- 525 cranking amps for 20 seconds
- Short circuit current over 1800A
- 17 amp hours
- 24 minute reserve capacity with 25amp load
- With metal jacket
- Length 7 1/16"
- Width 3"
- Height 7 5/16"
- Weight 15 lbs
- 2 year full warranty
- Rugged Drycell sealed design
- Military grade
- Vibration resistant
- 60% more starting power
- Deep discharge reserve power
- 2 year storage life
- 8-12 year design life
- Can be mounted flat or upright
- Lightweight aluminum weighs less than 1 pound
- Great for buggys, cars, and small aircraft
- Brushed finish suitable for painting
PC 680T Specs:
PC 680T Specs:
- 17 amp hours
- With metal jacket
- Length 7 1/16"
- Width 3"
- Height 7 5/16"
- Weight 15 lbs
- Military grade
that's it but it does require a charger nightly (at least in my 2 year experience with the battery, your results may vary)
Oct 2, 2015 02:23 PM
HIX
Sep 8, 2015 03:16 PM
