Clutch Force Question - Stock
Old Nov 27, 2007 | 10:20 AM
Vyper340's Avatar
Vyper340 has a spectacular aura aboutVyper340 has a spectacular aura aboutVyper340 has a spectacular aura about
I have noticed that my garage queen has developed something that I am not sure if I should be concerned about. If the car has been sitting for a week or so (climate controlled garage), the clutch pedal is harder to push in to start the car. When started all is normal but I have noticed this a few times now and am wondering if something is going. Any advice?
Stock orginal clutch with 26k miles
Old Nov 27, 2007 | 10:45 AM
dixie's Avatar
dixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to all
Same problem here,it's probably the accumulator,it's mounted above the gearbox ,looks like an oilfilter..Costs around 120$ without labor.
Old Nov 27, 2007 | 10:52 AM
DougNH's Avatar
DougNH is infamous around these parts
I have the same issue however it takes just 1-2 days of sitting for it to happen (2001 996tt 46k miles). Once I start the car it goes back to normal in about 30-60 seconds.
Old Nov 27, 2007 | 11:08 AM
Vyper340's Avatar
I'm guessing they have to drop the tranny to get to it...
Old Nov 27, 2007 | 11:15 AM
dixie's Avatar
Yes you have do drop the tranny a little bit,it's not difficult ,takes maybe 30 minutes to drop it.
Old Nov 27, 2007 | 12:01 PM
Vyper340's Avatar
Here's the word I just heard back on this issue:
Nope, that is normal. It is about three days that will happen as the accumulator looses pressure. That is normal.
Old Nov 27, 2007 | 01:59 PM
RiA's Avatar
RiA
RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !
Hmmm, check around your reservoir and see if you have fluid leaking. This is a sign of master/slave and/or accumulator going bad.
Here's my experience in order:
1. fluid leaking/stiff clutch pedal after sitting a couple days
2. dealer told me I overfilled the reservoir (which I didn't)
3. dealer siphoned fluid out of the reservoir
4. days later I had fluid leaking again
5. called dealer and informed them once again of the leak
6. dealer replaced slave
7. fluid stll leaking/stiff clutch pedal after sitting a couple days
8. dealer replaced accumulator
9. fluid leaking/stiff clutch pedal after sitting a couple days
10. Alex/James diagnosed master cylinder failure - I no longer use the dealer
11. tossed all that stuff and went to GT2 actuator
12. Me - happy camper
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
brockster
Jan 22, 2016 12:18 AM
Aug 21, 2015 09:56 AM
