HELP!! Radio Code Input
Old Feb 8, 2008 | 08:17 PM
igdawgi's Avatar
igdawgi has much to be proud ofigdawgi has much to be proud ofigdawgi has much to be proud ofigdawgi has much to be proud ofigdawgi has much to be proud ofigdawgi has much to be proud ofigdawgi has much to be proud ofigdawgi has much to be proud of
I changed my battery and the Nav requires me to enter the codes. I input the codes but they dont seem to work??? Any help? Is there a specific order the code goes? Radio, PCM, then BE??
Old Feb 8, 2008 | 08:25 PM
drh's Avatar
drh
drh has a spectacular aura aboutdrh has a spectacular aura aboutdrh has a spectacular aura about
If a smart person has not written the code somewhere in your owner's manual, you will need to call the Porsche dealer, give them your VIN and they will give you your radio code.
I called Sunset Porsche here in Oregon and once I got past the retarded female gate keeper, the service guy helped me out and I was good to go.
And I wrote the code in the manual...FWIW.
Old Feb 8, 2008 | 08:46 PM
igdawgi's Avatar
I think I have the codes.. Is there an order that its supposed to be inputed? Thanks
Old Feb 8, 2008 | 09:19 PM
drh's Avatar
drh
I have the CDR220 radio, and the procedure is to input the 4-digit security number using the multifunction buttons (1 through 0) There is a number corresponding to each button if you look closely.
Turn on the radio and punch in the numbers and you should be good to go.
Old Feb 8, 2008 | 09:59 PM
igdawgi's Avatar
i got the NAV unit... Is there suppose to be an order on how the codes are put in? I have to wait an hour to put a code now... =(
Old Feb 9, 2008 | 10:12 AM
porschedude996T's Avatar
porschedude996T is just really niceporschedude996T is just really niceporschedude996T is just really niceporschedude996T is just really niceporschedude996T is just really nice
How does the manual say to put the code in?
Old Feb 9, 2008 | 03:39 PM
igdawgi's Avatar
Yea.. I'm an idiot; I just went home and read the manual.. Apparently if you just change the battery, the code you only need is the PCM... Thanks
kkswow12
964
Sep 11, 2015 10:31 PM
Yogi911
Sep 9, 2015 08:20 PM
AuZZie
Sep 2, 2015 04:26 PM
