Clunking sound from driver front axle
Old Feb 9, 2008 | 11:40 AM
JonnyTTSB's Avatar
JonnyTTSB is infamous around these parts
Hello all,
I am hearing and feeling a clunking sound from the front driver side axle when I am backing up in reverse. Any ideas what this could be?
Thanks in advance for your help!
Old Feb 9, 2008 | 11:45 AM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
If you're lucky, it's the brake pads shifting in the caliper. You would hear it only once then. Other possibilities are CV joints and wheel bearings. Those would be more continuous and periodic noises.
Also check that the sway bar drop link bolts are tight.
Good luck.
Old Feb 9, 2008 | 06:48 PM
JonnyTTSB's Avatar
Thanks FAST FWD
Old Feb 9, 2008 | 06:52 PM
mtesh73's Avatar
mtesh73 is infamous around these parts
take a look at the drive axle as well, my brother just snapped his on the x50, pretty much the only thing stock on the car and couldnt handle the 640+ hp. he described the same sound. its worth a look.
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
gulf gt
Aug 27, 2015 10:27 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
