Saved $550 this weekend
Old Jun 22, 2004 | 09:01 PM
NC Bob's Avatar
NC Bob is infamous around these parts
Talking Saved $550 this weekend
Both my TT and Boxster were due for the 15K checkup. My local dealer wanted $350 minimum per car.
I downloaded the 15K check list and oil change procedures from Loren's site, bought the oil from Pep Boys and got all the filters, seals and oil filter removal tool from Sunset Porsche. Total parts including oil amounted to $153 for two cars. Job took about an hour for both. No drips, no runs, no errors. My auto mechanic son disposed of the old oil for me. Piece of cake.
Old Jun 22, 2004 | 09:14 PM
osu s2k's Avatar
osu s2k is infamous around these parts
where can i download the checklist ect.
Old Jun 22, 2004 | 09:26 PM
NC Bob's Avatar
http://www.renntech.org/forums/
You will be required to register as a user before you can download any DIY stuff. Good site.
Old Jun 22, 2004 | 09:45 PM
HotRodGuy's Avatar
also, walmart sells Mobil 1 dirt cheap. It's like $18 for a 5 quart bottle
Old Jun 22, 2004 | 09:52 PM
Scott in H-town's Avatar
Pioneer Member
Scott in H-town has a reputation beyond reputeScott in H-town has a reputation beyond reputeScott in H-town has a reputation beyond reputeScott in H-town has a reputation beyond reputeScott in H-town has a reputation beyond reputeScott in H-town has a reputation beyond reputeScott in H-town has a reputation beyond reputeScott in H-town has a reputation beyond reputeScott in H-town has a reputation beyond reputeScott in H-town has a reputation beyond reputeScott in H-town has a reputation beyond repute
0w40?
OMG. Didn't know that.
Old Jun 22, 2004 | 09:57 PM
HotRodGuy's Avatar
mine carries it
Old Jun 22, 2004 | 10:15 PM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond repute
Re: Saved $550 this weekend
Hey Bob, can I bring the C4S by when it's time for the service?
Old Jun 22, 2004 | 11:17 PM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
Other than inspecting the condition of various items, is the oil change with gaskets, o-ring seals and filter the only thing done for the 15K service???
Old Jun 22, 2004 | 11:36 PM
NC Bob's Avatar
Re: Re: Saved $550 this weekend
Heck yeah, man. I got those Boxster engines down.
Old Jun 22, 2004 | 11:45 PM
NC Bob's Avatar
Nothing a DIYer couldn't do himself. 30K is a little more involved.
Minor maintenance after:
15,000, 45,000, 75,000, 105,000 miles etc.
(24,000, 72,000, 120,000, 168,000 km etc.) OK
Diagnosis system: Read out fault memory
Change engine oil
Vehicle underside and engine compartment: Visual inspection for leaks (oils and fluids) and abrasion (lines and hoses)
Power steering: Check the fluid level
Coolant hoses: Check condition;
Radiators and air inlets at front: Visual inspection for external contamination and blockage;
Coolant: Check the level and antifreeze protection
Particle filter: Replace the filter element
Brake hoses and lines: Visual inspection for damage, routing and corrosion. Checking the brake fluid level
Drive shafts: Perform a visual inspection of the boots for leaks and damage
Tires and spare wheel: Check the condition and the tire pressure
Check the door locks, lid locks and safety hooks of the front lid to ensure that they are secure and functioning properly:
Check lid lock, front and rear; Check safety hook, front lid; Function test, check door lock; Check door and lid tightening torques; Check inner release of luggage compartment (Trunk Entrapment)
Vehicle lighting: Check function; All headlights: Check adjustment; Horn: Check operation.
Windscreen wiper/washer system, headlight washer: Check fluid level and nozzle settings, pay attention to antifreeze protection in the winter months.
Electrical equipment as well as warning and indicator lights: Check operation.
Test drive:
Remote control, front seats, foot and parking brakes (also actuation travel), engine, clutch, steering, transmission, ParkAssist, automatic speed control, heating, air-conditioning system and instruments: Check operation.
Oils, fluids: Visual inspection for leaks
Old Jun 23, 2004 | 12:21 AM
rockitman's Avatar
Thanks Bob!!!
Old Jun 23, 2004 | 12:26 AM
NC Bob's Avatar
Here's the major maintenance check list:
Major maintenance after:
30,000, 60,000, 90,000, 120,000 miles etc.
(48,000, 96,000, 144,000, 192,000 km etc.) OK
Polyrib belt: Check condition
Change the engine oil and oil filter
Replace the spark plugs
Air cleaner: Replace the filter element
Fuel system: Visual inspection for damage, routing and secure fit of line connections
Parking brake: Checking the free play of the parking brake lever
Brake system: Visual inspection of the brake pads and brake discs for wear
Clutch: Check the play and pedal end position
Steering gear: Visually inspect the bellows for damage
Tie rod joints: Check the play and dust bellows
Axle joints: Check play, visual inspection of dust bellows for damage, check screw connections of running gear adjustment facility, front and rear, for secure fit
Exhaust system: Visual inspection for leaks and damage, check suspension
Tires and spare wheel (collapsible wheel): Check the condition and the tire pressure
Seat belts: Check function and condition
Test drive:
Remote control, front seats, foot and parking brakes (also actuation travel), engine, clutch, steering, transmission, ParkAssist, automatic speed control, TC/PSM switch, heating, air-conditioning system and instruments: Check operation.
Softronic
997 Vendor Classifieds
Sep 10, 2015 03:42 PM
Softronic
Sep 10, 2015 03:40 PM
HIX
Sep 8, 2015 03:16 PM
Softronic
Sep 7, 2015 07:01 PM
