Instruction needednon fog lamp swap
Old Jun 28, 2004 | 03:02 AM
JK996TT's Avatar
JK996TT is infamous around these parts
I want to install fogs to match headlamps...how is it done? Thanks in advance!
Old Jun 28, 2004 | 03:08 AM
20C4S's Avatar
u need to remove the whole head light unit. check the owner manual. very simple & take u 5 minute each side to take the unit out swap the bulb.
the fog light bulb is H3. i have PIAA 4300K xenon match bulb (MAKE SURE U GET 55W) and it matchs 100% with my headlamp.
got mine from www.imotorgear.com a while ago. good & fast customer service.
hope this helps!
Old Jun 28, 2004 | 03:28 AM
JK996TT's Avatar
Cool..thanks!
Old Jun 28, 2004 | 09:21 AM
Under PSI's Avatar
Under PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud of
hope this helps!
I found 3800k, 4150k and 5000k but no 4300k. Are you sure about the number or did I just miss it on the website?
Old Jun 28, 2004 | 01:41 PM
msindi's Avatar
I have 4150 in mine and thge match is perfect - check my sig...4150 and 4300 are extremely close and hard to tell apart...
djhill
Oct 29, 2015 07:04 PM
