PE 700 whp?
Old Mar 11, 2008 | 03:45 AM
  #31
S4corrado996TT's Avatar
S4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really nice
Originally Posted by WOODTSTER
NertRod:
Mid to high 500's AWD
Mine made 628 RWHP on Proto's DynaPack (which can read slightly high)
I agree with Scott at Divexxtreme and based on several of my ACTUAL Perfomance
numbers in real world situations: 650-675 crank HP @ 1.3 bar
I ran an 11.03 at 134.5 mph on my 19" Michelin Street Tires (PS2) after driving my car
2 hours each way to the drag strip on them. I did NOTHING to prep the car, drove
thru the water box, did a sissy *** launch and some granny shifting and produced several runs in 11.03 to 11.18 all at 133.5 mph or above.
A more AGRESSIVE driver in my car on THAT SAME DAY would have easily broken into the tens. You also see my 0-186 mph is 27 seconds flat and 60-130 mph has been in low to high 6's.
MK
Marty! Is K24/18G's like the setup you have producing 650~675 crank HP running with pump gas. And if we want to attend 700+ crank HP, do we have to run racing fuel?
Old Mar 11, 2008 | 08:44 AM
  #32
WOODTSTER's Avatar
Yes,
You will have to run race fuel in anybody's set-up if you care about your motor.
My dyno was done on MS103 (99 Octane Unleaded thru cats).
I now am catless with much better headers and run MS109 (103 oct unleaded).
You must run good gas period.
MK
Old Mar 11, 2008 | 08:47 AM
  #33
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
Yes,
MK
Marty: Any reason why you wouldn't run MS109 through cats? I've always been told it's safe to do as long as the gas is unleaded. I've ran both VP104 and MS109 in my car with cats on it.
Old Mar 11, 2008 | 08:31 PM
  #34
Question
Yes,
MK
Marty! Thank you for your reply! The other thing I wonder is how many crank HP K24/20G can produce with pump gas? Is K24/20g requiring our engine to modify internal such as connecting rods and better forge pistons in order to sustain the power generated by K24/20g?
Old Mar 11, 2008 | 08:36 PM
  #35
No you do not need a engine build... I drove the only one 20G set up.... and its awesome...
it produces about 40 rwhp more over the 18gs... but does not cost anymore then the 18gs...
Its when you get into the gt3076R turbos is where you need to start worrying about bending rods... generally speaking that is...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Mar 11, 2008 | 08:51 PM
  #36
Thanks Mark! However, why most pepole in here opt for 24/18g rahter than 24/20G? Is there any concern over 20gs?
Old Mar 11, 2008 | 09:02 PM
  #37
Because the tuner does not offer it. It was originally custom done for Bobby from Tulsa.
9.66
click to view
Old Mar 11, 2008 | 09:08 PM
  #38
I see! Tks Mark! I guess I may ask Todd K to custom a set for me!
Old Mar 11, 2008 | 09:15 PM
  #39
You sure can... and if he resists tell him you talked to me LOL
9.66
click to view
Old Mar 11, 2008 | 09:55 PM
  #40
chenshan's Avatar
chenshan is a jewel in the roughchenshan is a jewel in the roughchenshan is a jewel in the rough
You are gonning to run faster than me, damn! I should wait a little longer......
Old Mar 11, 2008 | 09:57 PM
  #41
chenshan's Avatar
Maybe I will send my 24/18gs to Todd and modified into 24/20gs. It's never enough HP........
Old Mar 13, 2008 | 08:17 PM
  #42
Mark! Thank you very much!
Old Mar 13, 2008 | 09:13 PM
  #43
RCNJ's Avatar
RCNJ is infamous around these parts
Be ready to run high boost if you wanna make more power than 18g. I believe they're capable of around 680 rwhp at 1.6 or 1.7 bar. I have 18g's now and I will be doing a motor build so I'm thinking of trying out the 20g's before spending the money on GT30's. Markski speaks very highly of these turbos so I figured its worth a shot.
Markski- John is starting my build next month. I'll be giving you a call.
Old Mar 13, 2008 | 09:16 PM
  #44
unvmy996's Avatar
raudel , im in the process of converting over to 20gs.
Old Mar 13, 2008 | 09:22 PM
  #45
DMaffo's Avatar
DMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud of
I see alot of talk about HP numbers and quite honestly I have no clue as to where I was at.. I ran as mentioned a decent number on Todds basic entry level kit... NO injectors, no extra fuel pump..no hard pipe kit...no SLICKS!!! all out street falken tires...lol...
Dont worry about the number... I ran sooo many ppl that were supposed to have 700++HP+++ up to some clowns that claimed 900.... but ..they spun... the slid...they were all over the place while i was slamming gears all the way to my win... so... for a complete STREET car the K24/18g set up with Todds ecu worked AWESOME.... my clutch was ceramic so the launches were not as good.....but.... who cares.... most of the fun in these cars is when you get going anyhow.... Lots of options brother!!!
