Turbo Oil Sump / Drip Tank questions???
Old Mar 22, 2008 | 08:58 AM
zerosoul914's Avatar
zerosoul914 is infamous around these parts
Just a few quick question for you TT guys'...
What function does the oil sump / drip tank serve on your cars? Has anyone stock or otherwise, opted to remove it and run straight to the scavenge pump?
The reason I ask is because I just turbocharged my boxster and it's running a similar set up with a scavenge pump, but without the oil sump. So far so good, the only issue being is that the turbo is blowing out oil out of the downpipe and the turbine seal. I'm betting that this is due the restriction/design configuration of my current set up. Any 2 cents would be appreciated
Joe
Old Mar 22, 2008 | 09:20 AM
Sonny's Avatar
Sonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud of
The drip tank is there as a reservoir to give it a "chance" for the oil to be sucked up by the turbo scavenge pump, since the turbo pump lags a little against the oil press build up the the oil inlet of the turbo, if you are using a "gravity feed", you should place the turbos high enough for the oil to scavenge properly out of the turbos.
Old Mar 22, 2008 | 09:28 AM
Ahh makes sense. My turbo isn't gravity dripped, so I'm using a shurflo pump but it looks like I got to fabricate a drip tank now
Old Mar 22, 2008 | 09:35 AM
Sonny's Avatar
That electric pump won't cut it if you are using standard turbos (non ball bearing), it might work with GT turbos since the oil demand for them is pretty low.
Old Mar 22, 2008 | 10:09 AM
What pump would you recommend?
I'm using the same pump as the STS (rear mounted turbo guys) and the turbowerx pump they use to scavenge twins just fine ( I'm using a small single). So far it doesn't seem like the turbo is starved for oil, in fact it's coming apart because there seems to be too much of it
Oh quick edit:
I think I just fudged up the oil return when I started looking more into it. I've been using a 3/8th I.D return from the turbo to the scavenge pump. It looks like I was supposed to use at least 1/2" ID. Whoops ;x
COBB Tuning
Jan 1, 2025 09:02 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
Lucid Moment
Aug 20, 2015 02:22 PM
