Home Again..
Old Jul 5, 2004 | 03:34 PM
20C4S's Avatar
Originally posted by EL750
Arling,
unfortunately I DO have the 8-pod GT red brembos'
oops! no 18'' will fit then.
Old Jul 5, 2004 | 08:57 PM
cjv's Avatar
cjv
Moderator
Elliot,
Can you go over what you did to your car. It has been awhile and I am not sure I heard about everything you did.
Old Jul 5, 2004 | 10:35 PM
TTM0TION's Avatar
TTM0TION is infamous around these parts
EL750, fred had the big 8 piston's and got BBS i beleive to make him a custom set that would clear the brakes no problem. YOu should pm him.
Old Jul 5, 2004 | 10:37 PM
SteveH's Avatar
SteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud of
why would anyone buy a set of brakes that caused them to not be able to buy any good tires? I'm sure the next step down brakes with R-spec tires would stop way better than bigger brakes with 19s. Brakes are only as good as the traction they can get out of the tires.
That leads me to believe there must be SOME 18s that will work otherwise those brakes would be completely useless.
Old Jul 6, 2004 | 02:50 AM
dbelleperc's Avatar
I soon will be a supporting member
dbelleperc is infamous around these parts
Re: Home Again..
By the way I topped out in Germany @ 351km/h @ approx. 7250rpm.
351km/h is only 218 MPH, DAMN!
Old Jul 6, 2004 | 07:11 AM
EL750's Avatar
EL750 is infamous around these parts
Thanks for the feedback guys...
Chad, mods:
-cylinder heads intake and exhaust port machined like GT-3RS
-valves custom 41.5 and 37mm
-custom cams,pistons,liners
-ruf titanium rods
-engine block shuffle pined reinforced,crankshaft rebalanced
-gt-2 oilpump
-single mass flywheel, custom clucth
-560cc bosch injectors, 5 bar fuel pressure regulator , second fuel pump 350l/h
-turbochargers hotside k26 inlet 52mm outlet 56mm
-headers,exhaust
-GT-2 tranny mainhousing with internal oilpump and external oilcooling system, bearings synchros from GT-3 cup
-GT-3 CUP control arms front and rear with PSS9 coilovers
MeddlingKid
Oct 20, 2015 07:43 AM
bzibi
Southwest
Sep 30, 2015 08:03 PM
Bobbyfali
Sep 27, 2015 01:55 PM
