Shock remote adjustment cable help?
I need a cable to connect to the top of my motons (in the rear) so that I can adjust rebound without having to take the car apart. Anyone have any suggestions?
Please hurry!
Please hurry!
make an adaptor/bushing to fit on top of the threads with a socket head/ button head hardware and use a long t handle for adjustment accesss to adjust. use a carpeted covered plug tocover the access hole.
Re: Shock remote adjustment cable help?
Please hurry!
Please hurry!
Shank:
Got the Moton's from EVO. Talk to Mike at AWE as well. Perfect Power did the install.
I am going to try to use a flexible screw driver extension to do it. It is a little tricky comparing drives, 6 pt vs. 4 pt,... but I thinkI can get it.
The problem with a T-handle is it looks like I might have to go through the crappy Bose subs. Not sure yet.
even better if you have the bose speaker to cover the holes when in street mode. I take mine out for the track and you can have easy access to the holes. most likely you will only be making changes at the track. speakers have only 2 screws and slides out. easy.
Originally posted by john stephanus
I would be possibly be interested in this as well as I am going the Moton/ERP route.
That is a very smart decision. Cary is simply awesome and his knowledge on suspension tuning is unparalleled. Period.
I will be doing some stuff with him shortly as well.
ECS Tuning - VW
Sep 8, 2015 12:54 PM
andbos
Sep 7, 2015 07:13 PM
