Why aren't K26 turbos used on higher peformance packages similar to TTP?
Old Jul 15, 2004 | 05:22 PM
EL750's Avatar
EL750 is infamous around these parts
02 turbox50,
I am using K26 hotside, with modified internals. WE are pushing 750hp+. You really have to keep the engine above 4000rpm in order to have turbos spooled up. Boost starts @2600rpm, .4bar @3k, 1bar @4k, 1.4bar@4400rpm all the way to redline. Occasional overboost 1.5 bar.
Old Jul 16, 2004 | 12:44 AM
Rodis's Avatar
Rodis is infamous around these parts
How does the Tubi sound compare to Techart and Europipe? Louder, deeper, racy, . . . . Never heard Tubi before. Any feedback?
Ron
Old Jul 16, 2004 | 12:54 AM
limitup's Avatar
limitup has a spectacular aura aboutlimitup has a spectacular aura about
Wheelspin at 110 mph in an AWD turbo with "only" 750hp? You've got to be kidding...
Maybe in the rain, with the road covered in sand ...
Old Jul 16, 2004 | 05:48 AM
Zippy's Avatar
Originally posted by EL750
02 turbox50,
I am using K26 hotside...
Dude. If you are using a K26 on the "HOT" side, what in the name of Jesus are you using on the compressor side? K@#?
Mike
Old Jul 16, 2004 | 07:18 AM
EL750's Avatar
limitup,
I got consistent wheelspin @190km/h in German autobahn and in very good traction back roads. Same happened in Italy. Currently in Greece lights flash on dash even in 6th gear albeit not very good traction here. This occurs mostly going uphill, I guess because of the increased load to engine. Getting a new set of tires next week, hope this improves traction some. I think we are near 780hp, since @the dyno we got only 1.2 bar @4.4k rpm while running at least 1.4bar on the street.
Old Jul 16, 2004 | 07:24 AM
EL750's Avatar
Mike,
It's a custom K26 Inlet 52mm, outlet 56mm.
Old Jul 16, 2004 | 07:30 AM
rmrmd1956's Avatar
rmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of light
EL750
K16 is 40.6mm inducer 57mm compressor and 55mm turbine.
K24 is 42.7mm inducer 60.6mm compressor and 57mm turbine
K24 large wheel is 44.2mm inducer and 63.5mm compressor
What is K26?
Old Jul 16, 2004 | 08:10 AM
EL750's Avatar
rmrmd1956,
I'm going to give TTP a call tomorrow to get the #"'s.
Jun 10, 2017 07:45 PM
socialpro
Cayenne 958
May 18, 2016 09:58 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
Oct 6, 2015 05:20 AM
ModBargains
Aug 20, 2015 12:28 PM
