Side skirt installation tips
Old May 6, 2008 | 10:44 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Anyone know how to install a side skirt on a 996tt. Drilling holes, etc. Appreciate all the help I can get.
Old Aug 20, 2008 | 02:34 PM
Flyer007's Avatar
Flyer007 is infamous around these parts
I just got skirts in also. How did you make out?
Old Aug 20, 2008 | 06:23 PM
bimmer81's Avatar
bimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to behold
are you referring techart side skirts?
Old Aug 21, 2008 | 09:25 AM
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
you apply a thin layer of silicon on the inside of the skirt for a good tight seal
Old Aug 21, 2008 | 09:30 AM
vividracing's Avatar
test fit the side skirts first to make sure you dont have to do any sanding and they fit flush. Once that is done, have them painted. Wipe down the part of the body the side skirts will fit to with some rubbing alcohol. Line the side of the side skirt that touches the body with 3M double sided tape. Press the side skirt in place and hold it there for about 5 minutes. Drill in the front wheel well and rear wheel well 1 or 2 screws to secure the side skirt. The underside should fit with the factory clips. If not, drive the holes and then use screws, clips, zip ties, whatever.
http://www.vividracing.com/forums/pr...mes-alive.html
Lowtush
Jan 25, 2022 10:48 AM
manishdutta
Aug 21, 2015 09:49 AM
